Cutting down the lugs on rice patty tires
/ Cutting down the lugs on rice patty tires #1
suburban99
Anyone ever tried cutting down the lugs on rice patty tires? I am going to trim mine down by an inch or so as they are tearing up my gravel driveway. Tractor is an E-14 Hinomoto 2wd with 8-18 rears. Your thoughts?
/ Cutting down the lugs on rice patty tires #2
How are you going to do it.
If with a grinder BE CAREFUL!
Ive got a friend that got tore up doing it.
Good quality hot knives are the way to go but a good one is expensive.
/ Cutting down the lugs on rice patty tires #3
I know someone that cut their rear tire lugs.
He used a sawzall and he dipped the blade in oil for every cut he made.
He took about 2 inches off the tires.
I was going to use a sawzall. Or a grinder with a carbide blade. i will let you know how it goes.
/ Cutting down the lugs on rice patty tires #5
Its too badd you cant do burn outs to remove rubber :laughing: .
I am not sure if a siping tool is wide enough to cut the lugs.
sawzall + WD40= success.:)
Harlo HP6500 (A60462)
Kubota L3130 (A53317)
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2014 Ford Transit Connect Passenger Van (A59230)
2014 Ford Transit...
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
2011 Mercedes Benz GL AWD SUV (A59231)
2011 Mercedes Benz...
