Cutting down the lugs on rice patty tires
   / Cutting down the lugs on rice patty tires #1
suburban99
Anyone ever tried cutting down the lugs on rice patty tires? I am going to trim mine down by an inch or so as they are tearing up my gravel driveway. Tractor is an E-14 Hinomoto 2wd with 8-18 rears. Your thoughts?
   / Cutting down the lugs on rice patty tires #2
How are you going to do it.
If with a grinder BE CAREFUL!
Ive got a friend that got tore up doing it.
Good quality hot knives are the way to go but a good one is expensive.
   / Cutting down the lugs on rice patty tires #3
I know someone that cut their rear tire lugs.
He used a sawzall and he dipped the blade in oil for every cut he made.
He took about 2 inches off the tires.
I was going to use a sawzall. Or a grinder with a carbide blade. i will let you know how it goes.
   / Cutting down the lugs on rice patty tires #5
Its too badd you cant do burn outs to remove rubber :laughing: .
I am not sure if a siping tool is wide enough to cut the lugs.
sawzall + WD40= success.:)
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2005 GENIE Z-45/25 TELESCOPIC LIFT (A51246)
2005 GENIE Z-45/25...
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
2018 TAKEUCHI TL12V-2 SKID STEER (A51246)
2018 TAKEUCHI...
2024 CATERPILLAR 255 SKID STEER (A51246)
2024 CATERPILLAR...
2014 Chevrolet Silverado 1500 Pickup Truck (A51692)
2014 Chevrolet...
