Cutting down the lugs on rice patty tires
   / Cutting down the lugs on rice patty tires #1
suburban99
Anyone ever tried cutting down the lugs on rice patty tires? I am going to trim mine down by an inch or so as they are tearing up my gravel driveway. Tractor is an E-14 Hinomoto 2wd with 8-18 rears. Your thoughts?
   / Cutting down the lugs on rice patty tires #2
How are you going to do it.
If with a grinder BE CAREFUL!
Ive got a friend that got tore up doing it.
Good quality hot knives are the way to go but a good one is expensive.
   / Cutting down the lugs on rice patty tires #3
I know someone that cut their rear tire lugs.
He used a sawzall and he dipped the blade in oil for every cut he made.
He took about 2 inches off the tires.
I was going to use a sawzall. Or a grinder with a carbide blade. i will let you know how it goes.
   / Cutting down the lugs on rice patty tires #5
Its too badd you cant do burn outs to remove rubber :laughing: .
I am not sure if a siping tool is wide enough to cut the lugs.
sawzall + WD40= success.:)
LMC G500-500A LOT IDENTIFIER 217 (A53084)
LMC G500-500A LOT...
10' CONTAINER (A51248)
2012 John Deere 7230R (A53472)
2012 John Deere...
Toro Mower (A50324)
Toro Mower (A50324)
UNUSED CFG QUICK ATTACH HYD POST DRIVER (A51248)
UNUSED CFG QUICK...
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
