Quick question about new FEL
/ Quick question about new FEL #1
netwayne
Tar Heels Baby!
Just got the 200CX FEL and ballast box for our 2305 and I see this attachment will probably be my favorite. Quick question on the reattaching. Is it normal for the hydro fittings to ooze hydro fluid when making the hose attachments? Is this being caused by the moving of the control stick prior to the hose reattachment, which is suggested in the manual for the reattachment procedure?
/ Quick question about new FEL #2
When you remove the fel is when you relieve the pressure prior to taking the hyd. lines off. This is what you are doing when you move the control lever around.it is normal for a little oil to come out when connecting or disconnecting hyd. lines because obviously there is oil in them!
/ Quick question about new FEL #3
Yes they all slobber some when connecting and disconnecting. One problem can occur when you disconnect the loader and because of increasing air temps. or the loader settles a little can cause higher pressure in the disconnected line which makes it difficult to hook back up, as the pressure on the check ball must be overcome. Sometimes that is not so easy to do. If you can push against a clean piece of wood, or cover the ball with a couple of layers of shop towel then you can rap it sharply with a piece of wood like a hammer handle. The shop towel keeps you from taking a shower in oil and also helps protect the ball. Don't hit it with metal, as you are liable to damage the ball and cause leakage.
James K0UA
/ Quick question about new FEL #4
Yeah, before the couplers seat tight you are compressing the ball stops which allows some loss of fluid. No problem there.
What you do have to worry about is when you can't recouple them because pressure wont allow you to compress the balls, there are several threads about how to deal with that, so I wont get all into it now, just warning you that it is fairly common and if it happens don't panic or think something is broken.
There are a few tricks to releasing the pressure, when you do, much more fluid is lost and can really fly out with force so you have to be careful.
You can search for threads like, "can't attach my loader hydraulic lines" or something along those lines to find the solutions.
JB
/ Quick question about new FEL #5
Wow. "great minds think alike":D:D
James K0UA
/ Quick question about new FEL #6
OK, James was giving the same advice with more detail as I was still typing.
So you see it is something that's happened to many of us, and you may experience if you remove your loader often, especially if you leave it off for extended periods.
JB
/ Quick question about new FEL #8
You can make a tool to relive the pressure for under $10. It's one of those things you don't need until you need, and then you realllly need it.
/ Quick question about new FEL #10
Looks good just remember to put a heavy rag over it.
I use to have the problem all the time with my truck mounted snow plows, I would just tap the ball against the plow to relieve the pressure, get a little extra ooze.
But when I had it happen to my loader, it had some serious pressure and when I got it to relieve I took a shower in H fluid :mad::eek:
JB
/ Quick question about new FEL #11
wow thats homemade? great job.
You didn't see my starting point. :)
CLECO SHEET HOLDER PLIERS from Aircraft Spruce
Trust me, I'm not an experienced fabricator - just reasonably innovative.
I used this very fancy CNC grinder to get the jaws to fit.
You can use a rag if you want to avoid mess, but the cup that's naturally built into the tool slows down the jet of fluid *and* directs it away from the user. It's just about perfect for the job (I do wish the jaws were a little thicker; they end up being pretty thin when the grinding's done.)
/ Quick question about new FEL #12
Reread his post. Sounds like he is putting pressure on the tractor side.:confused3:
/ Quick question about new FEL #13
Yes, if he moves the control stick while engine is still running, but the manual does mention to move the stick with ''engine stop'' prior to making connection so to release any pressure on the tractor side, and believe me, you have to do it or else your in for a few bad words. :mad: You are also right in your previous post, it is very important to do the same when disconnecting the FEL and let it settle so to remove all pressure in FEL hoses. Makes it a lot easier to reconnect. :thumbsup:
2022 EZ-GO ELITE...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
Agline ADM109 Disc Mower (A64047)
Agline ADM109 Disc...
2016 CATERPILLAR  730C (A63569)
2016 CATERPILLAR...
2008 DOOSAN G25 GENERATOR (A63569)
2008 DOOSAN G25...
2023 J&J TRAILER (A63569)
2023 J&J TRAILER...
