2810 - 4 wheel drive
/ 2810 - 4 wheel drive #1
juddmyers
I have a 2810 and the 4 wheel drive doesn't work. Can anyone help point me in the right direction to start troubleshooting.
No bad sounds come from the tractor. It drives with the selector in either 2 or 4 wheel
/ 2810 - 4 wheel drive #2
Check the linkage from the lever to where it goes into the side of the transmission. If all of that seems to be working correctly, then lift the front wheels of the ground hold one wheel and turn the other wheel, while doing this check to see if the drive shaft is turning and make sure one of the driveshaft connector sleeves are not stripped out. Also if your 4WD is engaged you shouldn't be able to turn one front wheel while holding the other. If you find no breakdown at any of these points the problem is probably in the transmission case. Good luck with it.
Can you tell me what hydro fluid to put in and where? I have a clear window above and to the right of the pto shaft. Its showing low, I want to add some to it. There is a spot right above the pto, I just want to make sure that's the right spot.
I jacked up the front end and put a block under one wheel. I then spun the other wheel by hand and it did spin.
/ 2810 - 4 wheel drive #5
You are correct about where to fill the transmission. Put the 4WD in gear and see if you can still spin it. Maybe you will hear where the weak point is.
/ 2810 - 4 wheel drive #6
2025 Polaris Ranger XP1000 (A60462)
2025 Polaris...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
2013 Tahoe Q4 Boat with 2013Tracker 18ft S/A Boat Trailer (A61569)
2013 Tahoe Q4 Boat...
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59906)
2007 STERLING...
2019 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
2019 GENIE GS-1930...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
