buy or build a cab?
/ buy or build a cab?
some more. quess 4 is limit. not sure how else to do these pics.
few more.
4 more.
few more.
/ buy or build a cab? #25
Wow! How many man hours? Plexiglas? A hard door Curtiss is about 4 grand-I assume your motivation was.."I can do it better?"
over 100 hours but enjoyed doing this very much. all of the glass is the same as the winshield of a car or truck, laminated safety glass. even sprayed it with the latest waterborne ppg auto paint and clear that we had just switched over to at our collision repair center. i sealed all the welds inside and out with fiberglass and urathane sealer. full weatherstripping all over. only air leak is around control levers. next project is a heater with fresh air intake.
/ buy or build a cab? #28
That is a great looking cab!!
Did you remove your ROPS (I didn't read all the posts)?
Excellent job Dan. How loud is it inside?
thanks. loud enough that im not instaling a radio. hst is quite loud i find. i sometimes use ear plugs when using it over an hour.
/ buy or build a cab? #30
If you haven't yet, you might want to apply some sound deadening material to the metal surfaces.
thanks. yes rops is removed and built cab frame out of thick wall square tubbing for safety. this cab is very solid.
/ buy or build a cab? #32
Wow you sir are very talented, Great Job, I would be very proud if I could do that.
DevilDog
thank you for all the great compliments. this forum was a big help.
/ buy or build a cab? #34
very nice job just need patience and talent
/ buy or build a cab? #35
Wow!
That's awesome. Nice work, man.
(I gotta learn how to weld)
/ buy or build a cab? #36
That is a real nice looking cab it makes me want to build one. What was the number of the ppg paint you used?
/ buy or build a cab? #38
Nice job, one more reason for me to learn to weld properly.
What did you use for door hinges?
/ buy or build a cab? #39
I have been thinking of building a cab but not nothing as nice as this, I was thinking of just making one out of 2x4's and plexy glass with one door that i could just put on during the winter and remove the rest of the time. Has any one made a cheap smiple cab like that?
thanks. hinges are comercial stainless steel with needle bearings. same found on doors at grocery stores and similar places.
2014 Nissan Altima Sedan (A61574)
2014 Nissan Altima...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A65053)
2018 CATERPILLAR...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Straight Boom Crane Truck (A64194)
2015 Kenworth T880...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63689)
2021 Takeuchi...
