2320 rear leak?
/ 2320 rear leak? #1
JDinVT
Vermont
Have a few small drips under the rear end that happen after use. It must happen over the night. I am **** with my stuff - the tractor has 20 hours.
Any thoughts?
Josh
/ 2320 rear leak? #2
A leak is a leak and probably will not fix itself. A hose leak is one thing but this leak does not appear to be a hose. I would fix it.
/ 2320 rear leak?
I want to fix it. Having trouble finding the source.
/ 2320 rear leak?
Found and fixed. So the 3 pt hitch hits the rear drain plug and loosens it? Really?
All fluids are fine. Anyone else have this issue?
/ 2320 rear leak? #5
I have a similar leak, but mine appears to be coming from the front of the rear end (under the floor).. I have taken the seat off numerous times trying to find it, but no luck so far.. Really need to take the floor off and see if i can see anything..
Mine happens only after it has been run for quite a while.. I ran it for an hour 1 day and it never leaked.. BUT if i mow for an hour it will be dripping after i finish - but doesnt leak when not running..
/ 2320 rear leak? #6
Are you sure it's not just some hot grease dripping off of the mid PTO shaft or off of the mower deck?? Just my 2 cents.....
/ 2320 rear leak? #7
that was my first thought - I had just switched from 'green grease' to a moly lithium blend when i first saw the leak back in the spring.. the moly had a lower temperature rating.. I have tried looking at it from underneath but can really see much..
But it also happens when i have the MMM off and using the rough cutter.. but it could be residual grease still coming off as well though.
sometime soon i want to install a temperature gauge - and when I have that dash off I will go ahead and remove the floorboard to look for the problem..
Brian
LILLISTON 4R ROLLING CULTIVATOR (A63291)
LILLISTON 4R...
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
2020 DRAGON ESP 150BBL ALIMINUM (A60736)
2020 DRAGON ESP...
2017 International 4300 Box Truck (A62613)
2017 International...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
