problems with being overweight
/ problems with being overweight
Well I find that my jeans don't fit and I haven't seen my knees in ...oh, this is about overloaded trucks. Sorry, couldn't resist:D
LOL - actually I'm surprised I didn't see a response like this sooner. :laughing:
I thought Arizona was made of gravel, with no one living more than a few minutes from some.
Bruce
I wish. Everything around my place is larger than my tractor bucket. :)
/ problems with being overweight #25
I assume you don't have the original build sheet that came with the truck? That would tell you all you need to know about how much it can safely and reliably haul. Often trucks are built to haul much more than they are rated/titled at.
We have a '75 C60 dump truck and according to the build sheet is has a 9K front axle, 23K rear axle, double frame, and extra heavy suspension. The truck could easily gross 32,000lbs but is only rated at 24,000. Two reasons, the 9.00-20 tires and to keep it under CDL. With that said, we often load it to 30k if we aren't going far, it has farm plates on it so we are legal even at that weight. If it had been equipped with 10.00-20 tires it probably could have had a high GVWR. Your truck is a larger, heavier duty truck than this one, so I'm sure you could haul 33K easily and safely, the legal part is up to you.
I have farm plates also.
/ problems with being overweight #27
I should have been more specific, it has 'farm use' plates. They basically turn a truck into a road legal piece of farm equipment that can only be used for farm related work within 20-25mi of the farm. No registration, weight limits, etc. but they are limited on where you can go and what you can use the truck for. With the farm use plates in VA you could drive an 80k semi without a CDL (or license at all for that matter.)
I believe my farm plates are similar. They told me no CDL, can't haul for hire, and I'm restricted to 150 miles from home, and I cannot cross state line. No mention is made about weight restrictions.
/ problems with being overweight #29
What motor does it have? My neighbor has a 78 C60 that I maintain. Its a pig. Has a gutless 350 2 barrel and a 4 speed. 45mph is about all it has loaded or not. If it were not for that 2 speed rear end it would never get going.
Farm use in Indiana where I live is the same, 150 miles and no limit on weight or equipment. Only real kicker is you can not cross state lines.
Chris
/ problems with being overweight #30
Chris
Same motor and transmission. Not a speed demon but it gets the job done, for long distances it would be tiresome. It does 60mph unloaded on the highway, and 40-50mph is as fast as I go with a load. It was purchased new for mostly on-farm use which is probably why they went with the heavy axles and such but the smallest motor combo. Ours also has the 2spd rear, 8.85 lo, 6.65 hi ratio.
/ problems with being overweight #31
Sounds like the same rig, just a few years newer. Pretty good old truck and simple to work on.
Chris
60mph! I wish. The fastest I have gotten mine is 53.5mph and that is downhill with a tailwind! :laughing:
/ problems with being overweight #33
That C60 with a 350 2 barrel my neighbor has would not hit 60mph if you pushed it off the roof of a 60 story building.:D
Chris
/ problems with being overweight #34
Mr. Fuller if your driving the old highway toward Peach Springs. Doing 50mph. is flying. The chuck holes were large enough to lose a Volkswagon in.
Isn't there a gravel pit toward Ashfork close to where the old high way and new interstatre comes together. Used to be called the Pistascho rock quarry.
Keep up your posts enjoy the memorys of living So. of Seligman,Ariz.
The ranchers are the best friends anyone can make.
In your post of hauling water. consider a used milk tank from a dairy. insulated and stainless steel.
ken
ken
Rte 66 to Peach Springs is nicely paved now. I don't recall seeing a single pothole. There must be at least 20 -30 big rigs a day, 7 days a week, going into the Lhoist limestone quarry picking up limestone for cement factories.
Bo
ken
Ken,
I don't know about it, but I'll check it out next time. I go through Ashfork everytime I go up to the property. I do know there is a huge flagstone yard, with tons and tons of flagstone.
Bo
ken
Ken,
Anything in particular you want to see a picture of? To see how it has changed? I'll try to take it on one of our trips and then post it on the AZ Ranch thread. Thanks on the inside scoop on how things used to be. :thumbsup:
Bo
You guys have me curious. Whats flagstone? And why is it so popular?
Big flat pieces of rock that people use for walks and patios. I guess Northern AZ is one of the main sources.
/ problems with being overweight #40
Chris
My IH tops out at about 55mph/ 3400 prm. If I didn't have a tach I would swear that motor was turning speeds a NASCAR engine sees because it's screaming so loud.
(2) 8 LUG DROP AXLES (A64280)
(2) 8 LUG DROP...
Carryall 1700 4x4 (A61574)
Carryall 1700 4x4...
BUNDLE OF R19 INSOLATION & RD DUCT INSULATION (A64281)
BUNDLE OF R19...
2015 IC Corporation PB105 School Bus (A61568)
2015 IC...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
