Advice on electrical/water underground
/ Advice on electrical/water underground #21
have you thought about using PE irrigation tubing instead of PEX? its much cheaper i believe. and you are doing this to irrigate....
Right now I hand water but was going to shop around this winter for setting up some kind of drip system next year. I got the pex to heat the beds to get a jump on the season.
The line I am replacing is the main supply line to the house from the water wheel.
/ Advice on electrical/water underground #23
That is what I have used before is the polyethylene and also use it for conduit, in fact I was gonna use some of the old stuff to put the cable to the sat. dish underground in. Cant leave it on top of the ground tho cause the bears love to chew it.
I used that sos tape then coated it with liquid rubber then black tape over that before. I have used shrink tubing for small stuff but not familar with (mung in therm)
I have the wires just hose clamped together for now, tried to find aluminum fittings to put it together when I was in town but no luck will have to look online and see if they have large enough shrink tubeing to cover it. Know any good sites for elec. supplies?
MUNG = gooey mess to us in pennsylvania dutch country :laughing::laughing:
hs_so1
Made of thermally stabilized cross-linked polyolefin, enabling a recovered wall thickenss greater than that of the cable jacket replaced. Withstands severe mechancial requirements of U.R.D., submersible, and direct burial installations. Tubing, featuring and internally applied sealant, offers protection atgainst moisture, and may be used over lead, steel, aluminum, copper, standard plastic and elastomeric insulating materials.
big size
Product Results - HS12-30
smaller size
Product Results - HS12-6
smaller longer lenghts
Product Results - HS12-6-4
tom
