allis chamlers
/ allis chamlers #1
moose1
Member
Wabigoon , Ontario , Canada
Interntional McMormick B-275 , Allis Chamlers D-17 , Yanmar YM15D
picked up a tractor at a yard sale that has been sitting for some time can't find the model number on it anywhere . I found 2 numbers in the casting . on the bell housing it reads D17 3107 and on the trans. 120H . i am assuming that it is a D17 and 3107 is the serial no. would i be correct to assume this ? does anyone know a website where i can run those no.'s and get the year ?
/ allis chamlers #2
Found this on the internet.
Can't find Serial Number (SN) on D17
Bruce McKay Looked everywhere... not finding the SN of my D17. Please provide photo or detailed description of it's location. Maybe I just need to use degreaser on everything as I suspect I'm not finding it because of goo! (grease)
Thanks in advance.
daryl Check on left side of engine where engine block bolts to clutch housing, Should be stamped into clutch houseing on flat part of flange.
/ allis chamlers #3
From this website i think the serial number can't be 3107. 1958 seriaql number began at 4300.
D17 Serial Numbers:
1958: 4300
1959: 16500
1960: 28200
1961: 33100
1962: 38070
1963: 65001
1964: 70611
1965: 77090
1966: 80533
1967: 86061
Final: 89213
Don
/ allis chamlers
thanks for the quick response don .. yes indeed it is a D17 on the torque housing followed by 3107 . I'm wondering if some of these tractors were made here in Canada ? I by no means any expert but i think it'd gotta be in the 60's because it's coil points and condenser 12 volt and has a voltage regulator up by ignition . Were all the Allis Chamlers this way ? I thought maybe the earlier ones had mags
/ allis chamlers
oh and by the way i took brake clean wire brush and rags and srubbed that torque housing and those are the numbers D17 3107
/ allis chamlers #6
I am afraid we may need to see some photos here. If you could, a few shots of the whole tractor, and maybe a few more of the serial #
/ allis chamlers
k will take a few photo's and post after supper . Were the allis's only built in the states ?
/ allis chamlers
there is also a patent pending sticker on the left side of the tractor i will take a photo of the last patent on that sticker is a canadian one from 1964 if i'm not mistaken . will try to upload some phots after supper that might take a while unless wifey helps :thumbsup:
/ allis chamlers
[IMG]
[IMG]
[IMG]
[/IMG][/IMG]DSCF0641.JPG[/IMG]
hope this worked
/ allis chamlers
been trying for an hour to upload th photo's . it uploads them but then tells me i have a connection problem to trtactorbynet
/ allis chamlers
i've been trying for an hour to upload the photo's but had no luck .
/ allis chamlers #13
email me the pic.. i'll upload. pretty sure my email is open in my profile.
soundguy
/ allis chamlers #14
here they are:
/ allis chamlers #15
i will take a guess and say since the last patten filled acording to the tag says 1963 that it was made in 63 are later since before had how can you have a patten date instead of saying patten pinding
/ allis chamlers #16
Or could the date mean the date that the patent expires??? And maybe it is an early 58 or late 57 D-17????
/ allis chamlers
thank you sound guy for posting pic's .. Let the debate begin . Do patents expire ? the last 1 is a canadian one 1965 . That's my guess as for the year. I have some others pics as well if anyone thinks that may help . that is the model and the serial number in the photo right ?
/ allis chamlers #18
Patents do expire -- US utility patents now expire after 20 years, US design patents after 14 years. Formerly, utility patents lasted only 17 years.
I don't know about Canadian patents.
Steve
/ allis chamlers #19
I believe what you have is a 1957 D17.:thumbsup:
I was doing some googling and getting a little conflicting info, but some places list the the D17 starting in 1958 @ SN 4300.
But others list them as starting in 1957 @ SN 1001. So I believe this is what you have got.
But whatever year it is, I believe it is definatally pre 1960's, because of the metal allis-chalmers logo. The later D17's had it painted on the hood. NOT a metal plate.
/ allis chamlers #20
glad to help.
looking forward to seeing what ya do with her.
I have a 48 G model allis.
soundguy
John Deere 3025E (A64126)
John Deere 3025E...
Case 950 8 Row Air Planter (A63118)
Case 950 8 Row Air...
(2) 15.0/55-17 TIRES W/ 6 LUG RIMS (A64280)
(2) 15.0/55-17...
Rotary SPOA9-200 Automotive Lift (A59228)
Rotary SPOA9-200...
JOHN DEERE 544J SUPER TRACTION WHEEL LOADER (A65053)
JOHN DEERE 544J...
1983 John Deere 2940 Tractor (A62613)
1983 John Deere...
