What Bends/Breaks First :) Stump pushing or pulling...
/ What Bends/Breaks First :) Stump pushing or pulling... #1
TMR
Gold Member
Two Harbors, MN
Geed morning...always difficult to sort though discussion and get a feel for real world results/problems that you discover when you actually own/operate machinery.
I have a "tendency" to try just a little toooo hard when I am working a task...wether it is one last turn of the screw too many or one extra crank on the leverage bar ratchet...result is something "gives"...with less than desired results.
I have read discussions regarding "old" tree stumps being pushed out with the loader or pulled out with a back blade...here is my real world application question...
Assume I end up with a 30-40 HP CUT...maybe JD 3x20, Kubota 3x40 or similar size HP and frame. I have many (maybe 100+)jack pine stumps that were originally logged more than 10 years ago...likely 15+...not large...maybe 10"-14" diameter and about 12" stump height. They land is pretty gravely and drains very well so they have not been sitting in wet dirt.
My question is...what will I likely find if I am sitting on my new CUT as described above and I go out "determined" to try to "root out" my many stumps...and what is likely to "fail" if the stumps don't want to cooperate.
1) Is the FEL box the weak point or is the FEL arm structure bending the weak point?
2) Is there a blade that you mount on the front that is either mounted on the FEL arms...or mounted on a stronger mount?
3) I am "guessing" that you could pretty easily bend 3pt hitch parts trying to pull out the stumps?
I think you get my general question...I do not want to add a backhoe due to $$$s and also I think it would take a long time to dig up stumps one at a time.
I know a bulldozer would be the best "tool" but I am hoping that a medium framed CUT would have both the HP and frame strength to push out these stumps? w/o breaking/bending expensive stuff :)
BTW...stump pulling and moderate land contouring are two of my desired uses...in addition to what I might call "routine" bush hogging and FEL work...maybe mowing.
Thanks All...TMR
/ What Bends/Breaks First :) Stump pushing or pulling... #2
I suggest you pull them with a chain on the tractor's draw bar. That's about the strongest part of the tractor.
You can loosen the stump with the loader...just don't over do it. But when you pull it out, use the draw bar!
Thanks Roy...didn't think of that...I guess because I have never owned and/or operated a tractor :)
Just out of curiosity...how do you "link" the chain to the stump? Does this require part of the stump lifting so you can wrap under the stump?
Thanks...TMR
/ What Bends/Breaks First :) Stump pushing or pulling... #4
Thanks...TMR
I use chain wrapped about a foot or so above the base, but some guys like the chain higher up which would increase leverage. One determining factor is the type of tree and how the root system spreads.
Once the stump is out, you can drag it to where you want it (using the chain and draw bar) or the loader bucket...which ever is easiest.
Just remember, your tractor is a compact utility machine...not a bulldozer.
/ What Bends/Breaks First :) Stump pushing or pulling... #5
+1 on pulling with the drawbar, But I will say this, depending on how big we are talking about here, and how high the stump is, you are not going to pull big stumps with a CUT without a lot of digging down and cutting the roots that radiate out from the stump. You can dig with the FEL to a point and then may have to get off and sever the roots with a handle tool of some kind. I use an old maul, and have to sharpen it once in a while. Of course the higher the stump, you can hook up higher with your chain for more leverage to breakover the stump. Some here have mentioned using a home made "ripper" first to go around the stump and get those roots severed in an easier manner. Good luck, and let us know how your doing with this project.
James K0UA
James K0UA
A single point "ripper" with a strong blade would seem a good tool. Is there such a thing made commercially for those of us not "skilled" enough to make our own? I assume you would have on 3 pt and set in the ground to rip on the edge roots?
Thanks...TMR
:):) Thanks Roy...just told my wife that "the guys" said I need a bulldozer! :thumbsup::thumbsup: TMR
/ What Bends/Breaks First :) Stump pushing or pulling... #8
Actually, if the stump removal is the main task you have planned for the tractor, renting a dozer (with an experienced operator!) would be a cheaper option.
I guess I figured that out awhile back. However, this is not about "production" but about an "avocation". While I prefer to do it myself...I don 't want to dig out one at a time with a backhoe. What I am hoping is that with 15+ years of sitting they are "easier" to pull out than I am thinking. Maybe I need to go up to the property and dig a couple out manually to get a feel for their strength.
Thanks TMR
/ What Bends/Breaks First :) Stump pushing or pulling... #10
Thanks TMR
Well if they are 15 years old, depending what species, they may push over like a rotten tooth with the FEL or pull easy with the drawbar, Can you rent a tractor for a day and abuse the rental to find out how much trouble they will be? Sometimes old rotten stumps are a piece of cake.
James K0UA
James K0UA
Jackpine...not my favorite tree. Short stumps...maybe 12" tall...but not very big trees when cut...maybe 12" diameter up to 14"-16". I think I need to take a closer look. Last time up at the property I kicked one and it "seemed" pretty firm. Need to take a maul and shovel to try a few...TMR
/ What Bends/Breaks First :) Stump pushing or pulling... #12
Thanks All...TMR
Don't Push/Pull with the FEL........ Get them as lose as possible (with the other recommendations on this thread), then chains and the drawbar to pluck them from the hole. Don't ask me how I know this! :ashamed:
Thanks dtperks...ahh the "learning" curve...exactly what I am hoping to avoid (to the extent possible) :) TMR
/ What Bends/Breaks First :) Stump pushing or pulling... #14
I've had success with the following:
Get section of a log in the front loader and put it next to the stump you want to pull. Wrap chain around the stump and put it over the log and them to the draw bar. Now when you go to pull the stump, the chain going over the log has an upward and sideways force.
Good luck
/ What Bends/Breaks First :) Stump pushing or pulling... #15
Roy's right, of course, but the REAL answer is to rent a CUT and learn all the wrong things to do on their machine. . .:laughing:
/ What Bends/Breaks First :) Stump pushing or pulling... #16
Something like this:
/ What Bends/Breaks First :) Stump pushing or pulling... #17
That still works very well and provides a distinct mechanical advantage. Being pine, I suspect the roots have long since became humus and the stumps should pop right out.
However, Amonimum Nitrate, diesel fuel, a ziplock bag and blasting cap do a fine job as well.
/ What Bends/Breaks First :) Stump pushing or pulling... #18
Well I hope it all comes out as easy as you make it sound. I never was that lucky.
I took out many stumps either with a Massey 35 or a JD 3520. Implied a lot of hard work and generally lasted several days. My wife says I never get dirtier than with stumps. The first stump was only a few months old, the second stump here was left by the 1999 hurricane, so about 12 years old, very very little rot and immensely strong. Both Lambert Cypress.
/ What Bends/Breaks First :) Stump pushing or pulling... #19
... a lot of hard work and generally lasted several days.
... very very little rot and immensely strong.
Or cut a basin in the stump top with your chain saw and plant flowers in it.
Bruce
While mine may be tougher than I "hope"...they are no where near what you pulled out! Stumps are much smaller/15 years since logged...and Jackpine is not know as a "tough" rooted tree. On another property I have the Jackpine all get knocked down by the wind well b4 any Red or White pines will fall.
I am going to the property tomorrow and take a look...may try one or two ny hand to see how bad...:)
Thanks...TMR
PALLET OF HOSES (A68842)
PALLET OF HOSES...
2014 WACKER NEUSON (INOPERABLE)  HIF690 (A68842)
2014 WACKER NEUSON...
2013 John Deere 544K Articulated Wheel Loader (A66734)
2013 John Deere...
2018 Manitou MLT960 ST4 S2 13,000lb 4x4 Rough Terrain Telehandler (A66734)
2018 Manitou...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2016 Chevrolet Silverado 2500HD 4x4 Crew Cab Knapheide Service Truck (A68183)
2016 Chevrolet...
