Trans Fluid Refill
/ Trans Fluid Refill #1
jerkyboy
Upstate NY
Just replaced my HST, so I obviously had to change the trans fluid/filter. I added approx half of a 5gallon pail of SUDT and I'm not seeing anything on the stick. There rear tires are still off the tractor and it is not perfectly level, but close......what's the deal? Can I start it with the approx. 2.5 gals, which is what my manual calls for, or should I put a little more in until I'm getting a reading on the stick?
/ Trans Fluid Refill #2
try lowering the 3 point hitch all the way. Sometimes the actual level won't show until I do this on mine.
/ Trans Fluid Refill #4
How much came out? Before drain, I check level on stick. I then drain, measure how much came out, put that much back in, then check stick. Philip.
/ Trans Fluid Refill #5
Mine used more than the manual states when I replaced the HST. I figure there's a good amount of holdup in the HST that a change wouldn't pull out but a replace does. I think I went nearly a gallon over what the manual states for a change.
2020 Ford Fusion Hybrid Sedan (A66738)
2020 Ford Fusion...
Palfinger ILP 3300 3,300lb Truck-Under Lift Gate (A68183)
Palfinger ILP 3300...
2014 Nissan Versa Note Hatchback (A66738)
2014 Nissan Versa...
CATERPILLAR D1 CRAWLER DOZER (A65053)
CATERPILLAR D1...
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
2017 Ford Escape SUV. (A66738)
2017 Ford Escape...
