Rotary cutting pics
/ Rotary cutting pics #121
Three or four more days to go.
/ Rotary cutting pics #122
Nice.. let's you get into the "zen" mowing routine. I like wide open spaces for cutting, not so much backing and constant turns. Just mowed 15 acres here, usually takes about 7 hours with a 5 foot cutter.
Sean
/ Rotary cutting pics #123
Sean
You must really be moving or the grass must not be that high...I mow about 15 acres and it usually takes me about 12 hours but it is about 3 to 4 feet high when I cut and I use a 5 foot bush hog as well.
/ Rotary cutting pics #124
The grass isn't that dense in most places, weedy though. I usually mow that field in 1-high, just fast enough to get a decent cut and not get shaken to death.
Sean
/ Rotary cutting pics #125
Sean, that explains it ..mine it really thick in quite a few areas, about 5 acres of it are thick - really thick and I cut in 3rd gear and #2 speed. I will be posting my pics in a few weeks since I have to tackle it soon..
/ Rotary cutting pics #126
Sean
Actually on that farm, we have a mix of open and really tight places that I have to creep through watching the cab clearance as well as the trailing pull type 10'6" cutter. We also have some ponds to mow around, so those open spaces sure are a pleasant change.
/ Rotary cutting pics #129
Getting in some seat time! :D
/ Rotary cutting pics #130
/ Rotary cutting pics #132
Cutting on some hilly ground to keep the snakes away from the house. Yep it's that time of year.
/ Rotary cutting pics #134
Pretty neat pics Electrarc. Australia looks like the last frontier...one of the few places left. On some of those slopes and fields, can't they be burned? Seems you could disk a firebreak and pick your day to burn.
On your tractor...the seat rotates around? How does the steering wheel and controls rotate. Never seen anything like that...
Builder...That's a serious bushhog. 3 spindles. How wide is it?
/ Rotary cutting pics #138
Dave...I burnt a lot of land this year but the rains came early, so I have to cut this slope. I will make a small video on turning the operators position around. It only takes seconds.....Love it.
Cheers
/ Rotary cutting pics #140
Already posted these on "today's seat time" thread, but I'll re-post them anyway. Mowing the fire break/shooting lane between my land and state forest. About three acres worth.
Joe
Caterpillar 14G Motor Grader Parts and Service Manual (A63117)
Caterpillar 14G...
2007 Freightliner Columbia 120 S/A Day Cab Truck Tractor (A61573)
2007 Freightliner...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63689)
2022 Greenworks...
(2) DROP LEGS (A64280)
1974 Ford F600 Grain Truck (A63118)
1974 Ford F600...
1984 Cab Over K100 Big Cam 350 (A62613)
1984 Cab Over K100...
