kubota bx2200 with la211 loader
/ kubota bx2200 with la211 loader #1
DrDialtone
Kubota BX2200
I have never removed the loader. I assume when I do the hydro hose with the male end must store into the female coupler on the tractor.
/ kubota bx2200 with la211 loader #3
I take the loader off of my BX1800 several times a year. Raise the loader, put the support arms down, lower the loader, tilt the bucket down/forward a bit to relieve pressure from the pins, remove the pins, then pull the loader handle back to take the loader off of the tractor support.
About the hydraulics, they come apart and go together in just one way. The hoses on the loader stay with the loader, and the hose with the tractor will fit back on. On mine, that leaves a female exposed on the tractor and there is a plastic plug dangling there. Clean it, plug it, drive away.
/ kubota bx2200 with la211 loader #4
Hello & WELCOME to TBN!
I moved your thread to the Kubota Owning/Operating Forum. :)
/ kubota bx2200 with la211 loader #5
Yes it does, it is a little more difficult on the 2200 than the newer versions, but not a lot of trouble.
/ kubota bx2200 with la211 loader #7
With practice it gets easier, I got a loader dolly for mine, So I put it on the dolly, and then roll it to its parking place!
/ kubota bx2200 with la211 loader #8
The connectors are a little different on the BX2200 than later models and you can't back out for more room and you have to loop one of the hoses back into the tractor.
I have owned both and the newer models are a little easier.
/ kubota bx2200 with la211 loader #9
I forgot to releave the pressure from the lines after pulling the two black pin and prior to releasing the lines from the tractor only once.:D What a pain it was to get the line connected again. Try not to miss this step.
/ kubota bx2200 with la211 loader #10
Here is a picture of the hook ups that are significantly different from the BXxx60 Series.
2018 HYUNDAI VC2530152-JS DRY VAN TRAILER (A59575)
2018 HYUNDAI...
2017 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A59905)
2017 INTERNATIONAL...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
2012 BIG TEX PIPE TRAILER (A58214)
2012 BIG TEX PIPE...
2012 Acura TL Sedan (A59231)
2012 Acura TL...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
