Building A Stone Shed - Page 2
/ Building A Stone Shed - Page 2 #1
Mounted Madness
Gold Member
Cobble Hill, British Columbia
2014 BX2370 as of today
I'm playing catch up on how I was going to post this thread, so here goes...
After getting the cloth (to keep the gravel from sinking into the clay) and then the stone, I had to get the spoil out of the way. It is amazing how much dirt comes out of a hole you dig - it always seems like lot more then what the hole could hold - hmmmmmm:D
Anyway, after the gravel was tamped down, I layed down some rebar and re-mesh and forms for the eventual pour. Now, the rebar looks a little 'used' and in fact it is. I scrounged the waste from all the house building sites in the neighbourhood with the result that I saved a few bucks on rebar...plus I was overly generous in adding the stuff to the slab. I talked with an engineer friend with respect to the slab and at 5 inches thick throughout, with the rebar and modest size overall - there was no need for a thickened edge.
I bought ready mix concrete on sale at $3/60lb bag and that was at least a 50% saving, though a neighbour 'borrowed' 15 bags this summer - but that's a whole other story. I completed the slab and frankly, though it is far from perfect, for a one man job and done on a hot day, with multiple mixes and pours, it turned out okay. I'm striving for the rustic look, so the less then perfect handiwork is fine with me. I'm also trying to use all of the materials I've been accumulating over the last couple of years as left overs from other projects.
Following the slab, I started preparing for the walls. I've read quite a bit about slip form stone buildings, and planned on employing that method with this build. Basically inner/outer forms sandwiching the concrete and stone until it's set. Too much work and a pain in the butt for a one man operation, and from my perspective, lacks the rustic handbuilt look I'm working towards.
As can be seen in the pics, I used an inner form, walls will be 7 inches thick, vertical rebar was welded to the rebar in the slab and spacers above. I'll be using rebar at 16inch centres horizontally as well. I built the frame for the door with new pressure treated lumber.
Finally, I broke out the mixer again, started humping stone from my trailer to the back yard and laid down my first row of stone. Also, I'm using fine grit concrete rather then mortar, since the original plan was slip form and that is what is used there. I'm mixing it a little dryer then normal, and it works very well given that the first row of stone is well affixed to the slab and won't give up any of the stone that I've laid down - so it works.
As required, I've thrown together some pics as I have progressed...:thumbsup:
/ Building A Stone Shed - Page 2 #2
Consider adding a little lime to the concrete mix. It will make the mix a little more sticky.:):confused:
Are you going to split any of the stones?
Okay, I'll give it a try. I was going to put up another row today, but there's rain/thunderstorms predicted, plus its Sunday, plus my back is sore, so I'll do it tomorrow.
As for splitting stones, they all run from 2inch to 6inch, well within the size I need for these 7inch walls.
I told my wife it'd be 2 weeks to gitterdone...so I'm still in the ballpark...:thumbsup:
Don't you already have a thread goin on this?
Yeah, it was page one - I'm still learning the posting methods and was having a tough time uploading the pics for page 2...thus the confusion?
I just realized what your saying :eek:.
If I go into my thread - how do I 'continue' without starting a whole new thread...?????
/ Building A Stone Shed - Page 2 #6
Just go to your old post and continue by clicking the "reply" button like you do when you respond to someones question or comment.
For photo's, While in the reply screen, scroll down to "manage attachments" upload your photo, then click the submit button at the bottom.
/ Building A Stone Shed - Page 2 #7
Western pointed you to the right track.
Looking forward to reading about your project. Good pics too!
/ Building A Stone Shed - Page 2 #8
Just dawned on me; that shed will make a good smoke house!:thumbsup:
/ Building A Stone Shed - Page 2 #9
Just had some rain come through south west of where you are a few minutes ago. Not enough to run and hide from though!:laughing:
That looks like it's going to be a real fortress of a shed!:thumbsup: Looking good!
/ Building A Stone Shed - Page 2 #10
I'll second the lime. A mason I worked with had his own mixture I still use to this day. 1/2 bag cement, 1/2 bag masons lime and 18 shovel fulls of sand. The last is a variable at best but you get the idea.
2014 Nissan Altima Sedan (A59231)
2014 Nissan Altima...
KUBOTA M6S-111 TRACTOR (A59823)
KUBOTA M6S-111...
2017 Wacker Neuson LTV6 Towable Light Tower (A56857)
2017 Wacker Neuson...
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
2019 Chevrolet Silverado 6500HD 4x4 ETI ETC37IH 37FT Insulated Bucket Truck (A59230)
2019 Chevrolet...
2014 Chevrolet Tahoe SUV (A59231)
2014 Chevrolet...
