CO2 for MIG with beer regulator?
/ CO2 for MIG with beer regulator? #21
If you plan on using the Ironman gas regulator, it will probably have a CGA580 fitting for an argon based gas cylinder. You'll need to adapt it to a CGA320 fitting for CO2. Your welding distributor can fix you up.
That CO2 is pretty cold at high flow rates, so you could freeze up a regulator. If your CO2 regulator was previously used for beverage service, it will be set up for pressure and not flow.
/ CO2 for MIG with beer regulator? #23
Yomax, my only reason for bringing up the cored wire was because he had access to co2. Wasnt trying to change subject. :D , only tryin to help bud!
/ CO2 for MIG with beer regulator? #24
Didn't take it as changing the subject. No probs here..All good stuff.:thumbsup:
Pos. or neg. electrode for CO2 with flux core, or doesn't it matter at that point?
/ CO2 for MIG with beer regulator? #26
Flux core / Dual shield. If the wire requires gas, Use Elect. +.. No gas Elect. -Good luck.
/ CO2 for MIG with beer regulator? #27
Ok you guys got me interested in CO2 again...
I have the HF CO2 regulator, bought a year or so back for dirt cheap on a sale with a coupon..
I also have several large CO2 fire extinguishers that were being disposed of I want to try for welding. I already made up the hose and just need to make a stand to hold the extinguishers upside down as their draw tube is at the bottom.
Hobart Handler 210....and thanks Hobart (not) for including a free spool gun in the package after I bought mine.
Comments on my CO2 plan?
/ CO2 for MIG with beer regulator? #28
It never fails, there is always some jerk, (me) who comes along and throws a wrench into a fairly safe statement.:D;)
Lincoln's NR-5, and 5-A, NR-305, and NS-3M all run on DC(+). Always read the manufacturer's literature!;)
/ CO2 for MIG with beer regulator? #29
I stand corrected. I should have known on the NS3M. Sold a lot of it back in the day. ( doubt anyone on here will ever use it ) cool stuff.
This little critter tried some welding without reading the safety stuff in the manual. He caught a buzz off the feeder wire under my shop floor. No sissy MIG for him, he liked straight AC.
/ CO2 for MIG with beer regulator? #31
C 25 is the way to go. push or poll will also change penertration.
2009 Peterbilt 367 Flat Bed (A64047)
2009 Peterbilt 367...
Wolverine Skid Steer Concrete Chuter (A64047)
Wolverine Skid...
1997 Ford F-450 Dump Truck, VIN # 1FDLF47F6VEB26852 (A61165)
1997 Ford F-450...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A63276)
2015 FORD F-150...
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A64194)
2010 International...
