Backhoe for CK30
/ Backhoe for CK30 #41
Unless you are driving on a road I would suggest taking off the triangular slow sign on the back of the backhoe. If you do any work near trees/branches it just may bend. Don't ask me why I would know that. :) :D :)
Roger that. I will travel the local road occaisionally and put it on then. Of course my roads have as much ag equipment running them as cars/trucks most days and many don't have any signage. The local outlook is if you can't see a 100+ hp tractor towing a 10' + wide implement that's your problem. So I may not bother or at least won't fret about whether it's on or not. Good tip because I will not be operating the hoe in wide open areas much.
/ Backhoe for CK30
Final it's here, my new KB2475 backhoe. I have the 18 in bucket and had the bigfoot pads installed. Now just have to get used to operating this thing:D:laughing:
/ Backhoe for CK30 #43
Nice hoe, Karl. Are you going to connect up the toplink, too?
/ Backhoe for CK30
Why bother?
I don't know if i should connect the top link to the BH:confused: looks like it's made to connect it, but... i think it's a nice way to break the bracket from all stress from digging:confused2: I'll be ordering a 9 or 12 inch bucket tomorrow, 18 for stump digging is a bit too much.
/ Backhoe for CK30 #46
I don't connect mine. It is useful to connect if you need a place to store the top link or keep it out of the way but modern subframes are designed to support the BH without using the top link.
/ Backhoe for CK30 #47
I was told by dealer that Kioti does not recommend connecting the top link, at least on my CK20S.
We might all wonder why they put a bracket for a top link on the tractor if they do not want it connected???
/ Backhoe for CK30 #48
I don't think the top link is supposed to be connected.
I have never connected mine.
/ Backhoe for CK30 #49
Those back hoes sure look nice, but man, $7000 worth?? I don't know about that..
/ Backhoe for CK30 #50
I would connect it. Additional support and stiffness is good. I really like
the improvements made to the 2475 over the 2375.
What does your owner's manual say?
/ Backhoe for CK30
The manual doesn't talk about the top link, neither to put the rear remote in A or B.
I did alot of shopping around before buying, every dealer in the province of quebec quoted 7000-7500$ + tx for the KB2475, 18 in bucket and subframe, bigfoot pads another 395$. Rather expensive i though, and seeing what others are paying for elsewhere, a dealer in another province quoted me a NEW KB2475, 18 inch bucket, subframe, AND bigfoot pads for 6150$ +tx.:shocked: Boy do we get ripped off in quebec. Of coarse it was a 5hr away drive, but my 2 closest dealers are 2.5hr and 3.5 hr away.
Now that i have the BH installed gotta find some work for it:D i think i will be needing practice:laughing:
/ Backhoe for CK30 #52
Congrats on the the new hoe. Who did purchase it from? That seems like a really reasonable price ,the quotes i have been getting are higher then that for the 6 1/2 kioti hoe for my ck 20. (i am in ontario)
I see you have to license your tractors in Quebec, i can't beleve that they don't make us in ontario do it ,not like the government to miss a chance to charge us another fee..lol
/ Backhoe for CK30 #53
Hello Karl,
Do not hook up the top link. You will be asking for trouble and Kioti warns against it. Too Rigid with all that leverage. The one thing you do want to watch is the large mounting bolts on the subframe. That backhoe is very strong and you need to re-torque all those 8 large bolts that connect the hoe to the frame.
Do you dig it?
Dave G.
KiotiDave
/ Backhoe for CK30 #54
Where exactly did you hear that?
I have asked this question of Kioti factory personell at the World AG Expo
several times. I have had a long discussion about the improvements of
the 2475 over the 2375 with them more than once. Apparently, there is
nothing written about it in the 2475 manual (KiotiKarl).
I would be very careful about believing someone's opinion about this
before you know what experience or expertise that person has. Same with
any opinion that I state on TBN, too. I have arrived at my opinion thru
many years of questioning and reading docs from the tractor makers and
the backhoe makers, and performing my own tests and experiments. I
have tested OEM subframes and my own fabrications. I don't have all the
answers, so I welcome any and all scientific evidence to further this
discourse.
/ Backhoe for CK30
Hello Karl,
Do you dig it?
Dave G.
KiotiDave
Thanks for the info, i did retorque the rear bolts, even after 12hrs. 3 different dealers have told me not to attach the top link to the BH, other BH companies require that the top link be connected, and some not. :confused2: I'll simply wont attache the top link, and IF something wrong happens i'll simply trade the CK for a Deere.:laughing::D
/ Backhoe for CK30 #56
Per Kioti, DO NOT connect third link. Makes it too rigid. Need some "flex".
/ Backhoe for CK30
For those interested, these are the pages of my KB2475 manual for installing and removing the BH, if i read clearly, there is no mentioning of the top link. doesn't mean because there are holes/brackets that you have to put something in there:laughing: Dont want to start a debate here either.
/ Backhoe for CK30 #58
Simple question, why would the OEM of the back hoe put the brackets on the back hoe for the top link and then tell you not to use those very brackets that they put on and I assume to use? Very very :confused: ing to me. I'm glad that I have my Case 580 Super E, don't have to worry about these things. ;)
/ Backhoe for CK30 #59
My Rhino came with the top link brackets because the backhoe is sold as a 3 point hoe, the subframe is an option.
/ Backhoe for CK30 #60
Is this true of these other hoes? :confused: If so, then that makes sense, but I'm thinking that that may not be the case in some of these instances. :confused3:
Here are some similar links:
