Pushing T-posts in with FEL?
/ Pushing T-posts in with FEL? #1
Haywire
Central Kentucky
Tractorless :(
Anyone ever use a BX loader to push t-posts in? My shoulders have been giving me a fit today and I need to put a few posts in tomorrow. I'm kinda doubting the BX has enough front end weight to handle the job, but I thought I'd ask.
Ian
/ Pushing T-posts in with FEL? #2
Maybe add a good load in the bucket and do it that way.
/ Pushing T-posts in with FEL? #3
OMG! ROFLMA!
Come out here; only way to drive them at my place right now is to make a starter hole with the electric jackhammer :eek: Load the generator in the loader, drive out to where you want a post. Make starter hole. Then, an hour later you will have the first post driven. IF, you don't run in to rock an bend it :D
Ian
It's storming to beat the band right now and the runoff generally goes through the area where I want the posts, maybe the ground will be softer tomorrow. I'll get a scoop of gravel in the bucket and see how it does. I'll probably end up taking a handful of ibuprofen and using the shoulder wrecker instead.
Ian
/ Pushing T-posts in with FEL? #6
I push T posts in with a small Skid Steer (about 6500 lbs.) About the only time I have issues is in rocky ground. Sometimes a little tweeking on the post is required to get it level/vertical. Second person is very handy with this operation.
/ Pushing T-posts in with FEL? #7
I use my pallet forks for pushing in t-posts. I'm afraid of bending the loader bucket by using it for that purpose.
That's what I was afraid of. All that pressure on a small area of the bucket. I'm feeling pretty good this morning, so I'm just using the regular manual driver. I only have 6 or 8 to do anyway.
Ian
Edit... what I'm calling T posts aren't actually T posts either. It's those stamped metal posts with the punched out tabs you hammer down on the wire. I'm putting poultry fence up.
/ Pushing T-posts in with FEL? #10
I've seen t-posts pushed into slightly damp soft ground with the FEL on a TLB, but all I could do with the FEL on my B series tractors was pick up the front wheels.:laughing:
/ Pushing T-posts in with FEL? #11
I don't drive many posts but tools draw my attention in case I may want to use one. This air operated driver fascinated me so I did the internet searches for air driven post drivers. Rhino has one for around $4000.00, yep $4000.00 where this one above is $450 but then I found one at Northern Tool (it's on ebay but sure it can be bought from Northern Tool direct) for under $400. No, I'm not buying......now:) but if I were/do then I'd go for this one no more than I'd use it.
Striker Air-Operated Post Driver - 2 CFM 80-100 PSI New - eBay (item 280712114260 end time Aug-18-11 12:06:09 PDT)
Hey John... I'm gonna be down your way on Saturday. Getting a tiller from Barlows unless something changes this week.
Ian
/ Pushing T-posts in with FEL? #13
Ian
I'll trade you 4 18" tires on Chrome rims (listed on Lexington Craigs list) for your cultivator. Bring it with you and pick up the tires.:):thumbsup:
/ Pushing T-posts in with FEL? #14
Ian
Try the load first. You may be surprised.
/ Pushing T-posts in with FEL? #15
Depends what they're made of and what you are driving them into.
Steel ? Yes, if into fairly rock free soil.
F/glass ? No.
Broke it yesterday. Only thing I could find in a 2" wide square U bolt when I built it was 1/4". They couldn't quite take the strain. I'll have to go with backer plates and regular bolts when I get around to fixing it.
Ian
2010 INTERNATIONAL WORKSTAR 7400 BUCKET TRUCK (A65643)
2010 INTERNATIONAL...
John Deere 620 Quick Attach Loader with Bucket (A65640)
John Deere 620...
2001 INT 4900 DT 530 (A62679)
2001 INT 4900 DT...
2015 Ford F-550 Utility/ Plumbing Truck, VIN # 1FDUF5GYXFED42880 (A65563)
2015 Ford F-550...
White Oak Slabs (A65640)
White Oak Slabs...
Unverferth Lift Assist Wheels (A65640)
Unverferth Lift...
