Battery Operated Warning Lights
/ Battery Operated Warning Lights
OK...I found the light, all part and parcel...:thumbsup:
/ Battery Operated Warning Lights #24
i still wouldn't eat it!
soundguy
/ Battery Operated Warning Lights #25
Super Bright LEDs LED Lights, Bulbs, and Accessories
Found this interesting site. You can buy the components and build from the ground up as well as some pre assembled components, or complete units.
The great thing about this site is, they have several calculators to plug data into and give you the specs of what you need to build the project. Some of the input data is new to me, but each of their components have all the data listed, so it is almost like a "dummies guide".
Prices seems reasonable as well. If I go this route, I'll post the results
/ Battery Operated Warning Lights #26
plus.. hit a truck stop.. plenty of low current 12v LED amber and red lamp assemblies.. that and a digital blinker assembly ( not a bi-metalic strip type ).. and you can have steady or blinking lamps... CHEAP
soundguy
/ Battery Operated Warning Lights #27
I have one of these.
http://www.ledsafetylights.com/safety_lites.asp?catid=2
This also works great.http://www.truckntow.com/pc-22520-146983-nas-magnetic-led-safety-beacon.aspx
UPDATE:
I recently noticed that the amber flashers did not work. Upon inspection, I saw that the batteries had leaked and corroded the inside, ruining the lights.
It's kinda of strange that this only happened to the amber flashers and not the red ones. The both got about the same amount of use and had the same batteries installed in them...:confused:
/ Battery Operated Warning Lights #29
if you are lucky you can clean them up and get them to work again.
soundguy
/ Battery Operated Warning Lights #31
got a soldering iron? easy to fix with a battery enclosure.. or some roofing tin.
..or pigtail out to a side connector.. etc.. etc.. plenty of ways to get power to it as long as the mainboard survived..
soundguy
soundguy
Possibly, but I'll probably just keep them for parts...
/ Battery Operated Warning Lights #33
could be working parts!
soundguy
/ Battery Operated Warning Lights #34
as stated earlier truck stops do carry the exact brand pictured but for a little less money most all heavy duty truck supply house such as truckpro fleetpride truck-n-trailer and others will have them far less money have seen these in action by foxfire mad very good for the elements and quite bright.
Rogator RG1100 (A63688)
Rogator RG1100...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2017 Hyundai Santa Fe AWD SUV (A61574)
2017 Hyundai Santa...
2016 Tradewinds TG45-UL 45kW Generator (A61572)
2016 Tradewinds...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
