Battery Operated Warning Lights
   / Battery Operated Warning Lights
OK...I found the light, all part and parcel...:thumbsup:
   / Battery Operated Warning Lights #24
i still wouldn't eat it!
soundguy
   / Battery Operated Warning Lights #25
Super Bright LEDs LED Lights, Bulbs, and Accessories
Found this interesting site. You can buy the components and build from the ground up as well as some pre assembled components, or complete units.
The great thing about this site is, they have several calculators to plug data into and give you the specs of what you need to build the project. Some of the input data is new to me, but each of their components have all the data listed, so it is almost like a "dummies guide".
Prices seems reasonable as well. If I go this route, I'll post the results
   / Battery Operated Warning Lights #26
plus.. hit a truck stop.. plenty of low current 12v LED amber and red lamp assemblies.. that and a digital blinker assembly ( not a bi-metalic strip type ).. and you can have steady or blinking lamps... CHEAP
soundguy
   / Battery Operated Warning Lights #27
I have one of these.
http://www.ledsafetylights.com/safety_lites.asp?catid=2
This also works great.http://www.truckntow.com/pc-22520-146983-nas-magnetic-led-safety-beacon.aspx
UPDATE:
I recently noticed that the amber flashers did not work. Upon inspection, I saw that the batteries had leaked and corroded the inside, ruining the lights.
It's kinda of strange that this only happened to the amber flashers and not the red ones. The both got about the same amount of use and had the same batteries installed in them...:confused:
   / Battery Operated Warning Lights #29
if you are lucky you can clean them up and get them to work again.
soundguy
(1) 10000 LB GEAR REDUCTION DROP LEG TRAILER JACK (A57192)
(1) 10000 LB GEAR...
2018 John Deere 470G LC Hydraulic Excavator (A53421)
2018 John Deere...
Standing Metal Firepit (A55853)
Standing Metal...
(3) 14" I BEAM (A57192)
(3) 14" I BEAM...
2015 Ford F550 Bucket Truck - Versalift VST47 Boom - Powerstroke Diesel - Automatic - 4X4 (A55302)
2015 Ford F550...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
