4wd garden tractors
/ 4wd garden tractors #1
Taftag
Millis, MA
2012 Kubota GR2021
I have 2 mowable acres with fairly steep side hill/ down hill areas. I bought a cub cadet zero turn tractor 3 yrs ago and have regretted it because it cant handle the hills well and i get scuffs. Thinking about replacing it. Looking for suggestions and if a trade in might be an option because i'm into the cub cadet for over $4k with attachments
/ 4wd garden tractors #3
Deere has (or had...I don't follow the lawn tractor market) a couple AWD models (not zero-turn machines though).
Before you trade off....can you mow up and down slope? Think that would reduce the slippage and scuffing? Maybe a more aggressive tire tread? Or, filling your tires (probably not much weight can be added due to their size) or weights to increase traction?
I suggest you investigate these options before seriously considering a trade. You'd likely take a pretty good hit on any trade at this point in time.
Welcome to TBN!!
There is no way I could possibly go sideways without flipping in a couple places so I do go up and down, but a little bit on an angle because there is also a steep side hill in the middle due to a 12 ft underground wall from when the septic system was upgraded before I bought the property. I've also got a huge bed on the steepest part of the hill that I need to drive around and half of it is under pine trees where I have to make the turn at the top and its always a scary moment. I also have a cyclone raking system that I inherited from the prior owner, but can't use it in the front because its not powerful enough to pull the weight.
/ 4wd garden tractors #5
Sounds like you are on the same path that I was on. I bought a ZTR and tried to mow my hills and that didn't work out so well as you have described. I ended up getting a BX1500 with a 54" deck and that is the tool for the job. :thumbsup:
/ 4wd garden tractors #6
I have similar problems, i.e., I have to trim around trees on a 20 degree slope. I want a Simplicity 4WD lawn tractor for this, but another 12 grand on top of the price of my compact tractor is something I just can't bring myself to do. Guess I could look for a used one...
Until then, I'll just keep using with old JD 185 with rear weights to help with traction.
/ 4wd garden tractors #7
Hello & WELCOME to TBN!
I moved your thread to the Buying/Pricing/Comparisons Forum. :)
/ 4wd garden tractors #8
I mow a few steep hills. Cast iron wheel weights and R-1 tires will make a giant difference. Lower the rear tire air pressure as much as you feel comfortable with. Also, if you can, drive up the steepest hills and go down the shallower hills. There really isnt a safe way to go down a steep hill. :(
What is involved with wheel weights in terms of installation and cost? It might be worth a try but i dont want to throw good money after bad
/ 4wd garden tractors #10
Several companies make some pretty neat equipment for mowing on hills and slopes. For example, Kubota has a 4wd ztr-type mower (The "F" series), and you should also check out Ventrac and Steiner.
Those units are commercial type equipment, so unfortunately they are pretty pricey. A good used unit might be more affordable yet still have years of useful life. The trick would be finding one. Ebay, Craig's, dealers, on-line equipment traders, etc.
/ 4wd garden tractors #11
Im not sure about zero turns, but most garden tractors run 12" weights. Easy to find on eBay. They usually interchange no matter the brand. They run $50-$150 mostly. You need to measure the rims to see if they would fit.
/ 4wd garden tractors #12
I am very satisfied with the x749 Deere with 4x4ws, handles steep grades well. Built low and wide for good stability you can add wheel weights but don't think you would need them.
/ 4wd garden tractors #13
Have you looked at this mower?
SuperSlopeMaster: Commercial Steep Slope Mowers
I have seen one of these and they go straight up INTERSTATE freeway high angle overpasses.
/ 4wd garden tractors #14
I've got a steep (very steep in places) 1.4 acres that I also tried with a zero-turn and it was slipping downhill and tearing up the grass. Also uncomfortable on uphill turns, I know what you mean!
I bought a Cub ZTT (zero-turn tractor) and I absolutely love it. It has the zero-turn capability, but sits very low and wide, I can now comfortably mow the steepest hill sideslope. (took awhile to get used to the feeling) Not sure about other makes, but Cub makes a 42", 46" and 50" model. Definitely a whole lot cheaper than a 4wd garden tractor!
Good luck!
The jd 749is what i was thinking about but its expensive. However it would probably seem less expensive if i hadnt blown a few grand already on my cub ztt 46" with bagger. The jd dealer said blue book on it would be about $1k but i dont't know how to check that. Also wold consider buying used but nobody seems to want to get rid of those 749's in any of the used places ive seem online
/ 4wd garden tractors #17
An outstanding product, but be aware the green paint is known to be expensive. You can find a similar orange machine (Kubota... equally good equipment) for several thou less $, and there are other good brands also. It pays to do some shopping.
/ 4wd garden tractors #18
Grandad4,
Curious which model Kubota you are referencing?
When shopping last year I didn't find anything similar to the x749. The x749 is expensive for a garden tractor imo, IIRC I paid $13,100. +sales tax for the X749 with choice of 48 or 54" mmm, limited cat 1 hitch, 540 pto and 4 42# front suitcase weights.
/ 4wd garden tractors #19
Love these BX1500 Tractors.
* You can find a similar orange machine (Kubota... equally good equipment) for several thou less $, and there are other good brands also. It pays to do some shopping.
*Here's a couple of them .
*another 12 grand on top of the price of my compact tractor is something I just can't bring myself to do. Guess I could look for a used one.
I would go for a new or used Bx1500 or Bx18XX.
This one brand new cost me less than $7800.
More tractor for less money than the JDx749 or Simpilicty Garden Tractors and a step up from a garden tractor.
/ 4wd garden tractors #20
Grandad4,
I was thinking of the BX type machines, as LBrown noted. The x749 admittedly has some nice features, particularly 4 wheel steering, but the BX has all the basics to make a fine 4x4, diesel, hydro, power steering, mid-mount mowing rig for quite a bit less than $13k. Just comparing specs, the machines are more similar than different in weight, power, width, drivetrain, tires, wheelbase and so on. If the OP figures the X749 would do the job at his place, there may be some situation in which it would work while a BX wouldn't, but I don't know what it would be.
2011 KUBOTA KX91-3 SERIES 2 EXCAVATOR (A64279)
2011 KUBOTA KX91-3...
2014 Nissan Frontier Ext Cab Pickup Truck (A61573)
2014 Nissan...
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
2017 Ford F-550 4x4 Venturo ET25KX 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
2016 International DuraStar 4300 Dump Truck (A61573)
2016 International...
