Mowing - Ring Around the Trees
/ Mowing - Ring Around the Trees #1
DieselDon
Member
B2620
I'm loving my b2620 (60" mmm) but the obvious weight increase (upgrade from a JD345 lawn tractor) is leaving a significant ring around all trees while mowing. I've tried slowing down which helps a bit. And more recently, I've stopped doing the complete circles.
Any other ideas?
/ Mowing - Ring Around the Trees #2
Mow around the trees using a tic-tac-toe pattern (tree is in the center square) in repetitive passes.
Thanks for the reply. I've begun to do something similar to that (incomplete circles...like 1/4th at a time) but having 120 trees tends to add a bit of time:laughing:
/ Mowing - Ring Around the Trees #4
Ground can slope up @tree, forcing up inside guage wheels, making outer wheels contact ground. Repeated mowings leave "rings"...ask me how I know...:)
/ Mowing - Ring Around the Trees #6
Sounds like you need a zero turn mower for mowing and leave the tractor for... tractoring.
/ Mowing - Ring Around the Trees #7
That's why I don't like too many trees .
Trees belong in the woods not in the yard.
what?! no trees in your yard to stay cool?! how sad....
I have a few trees in my yard and love them. I too got the tire rings around the trees too until I came up with a solution that worked for me. It may not help in your case, but did for me. What I did was I planted hostas around the trees so I get a larger circle to drive around so the outside tires is not diggin in so much. Once the hostas grows thick- its just like a shade canopy to keep weeds down so I am not using my string trimmer. Love it! This past spring I was in process of thinning out the other hostas to plant around other trees I haven't done yet and still kick myself for not doing it earlier.
/ Mowing - Ring Around the Trees #8
LB, you are da man :D
re. circles around trees. I got the same thing on my BX23 w/the bar tires. When I switched to the turfs it lessened it quite a bit.
But likes been said, going slower also lessens it.
Dave
/ Mowing - Ring Around the Trees #9
We have one tree in my yard and it's an old Oak that was there when we built. I use an AC to keep cool.
We had planned on lots of trees, but decided against it. We are, however. surrounded by woods on three sides.
My neighbor has lots of trees and uses a John Deere CUT, ZTR and push mower, not for me.
I paid $2225 for the 60" mmm and sold my JD325 for $1900. Starting to wonder about that move, yet I like the long runs with the mmm.
Thanks for all the banter about trees, no trees, hostas, etc.
I picked up some new ideas
dp
/ Mowing - Ring Around the Trees #11
I put colored wood chips down around all the bases, I've seen the small colored stone used as well.
/ Mowing - Ring Around the Trees #12
We have a sh*t pile of trees. I prefer a '0' turn mower, in my case a CC 60" tank over a tractor, but then my tractors would make terrible lawnmowers......:D
John Deere X500 Riding Lawn Mower (A66285)
John Deere X500...
2022 EZ-GO ELITE...
Kubota Industrial Turbo Diesel Engine - Tag Missing - Pump Takeout - Approx. 80-85 HP Class (A63689)
Kubota Industrial...
2010 Kenworth T3 Class 7 Flatbed, 4x2, w Tuck-Under Liftgate (A63689)
2010 Kenworth T3...
2016 Etnyre Falcon Live Bottom Trailer (A62613)
2016 Etnyre Falcon...
2015 John Deere CX15 (A64126)
2015 John Deere...
