Steiger Super Wildcat
/ Steiger Super Wildcat #1
a109836
Southwest Oklahoma
steiger super wilcat, john deere 2850, ford 3600
I just bought a Steiger Super Wildcat to pull a 6 yard scraper, i'm planning on digging out my pond with it.
/ Steiger Super Wildcat #3
Welcome to TBN. Around here we have a saying
"If there are no pictures it never happened". Thats just our way of saying we like to see pictures of the projects.:)
/ Steiger Super Wildcat #4
We have a Steiger bearcat 210hp CAT 3208 on a 7 yard miskin that we maintain field drains/ ditches with and handles it very well , Nicer than some of our bigger tractors i think as the trans is easier to shift on the move . We dont use it for heavy field work any more but the tractors are strong enough just the V8 was their downfall ...keep the rpm's up/gears down and dont lug it too much. You gotta nurse those V8's or they will throw up!.
There are lots of these locally on smaller farms and in hedgerows with all kinds of engines in them ...neighbour has a wildcat with a deutz air cooled V8 in it .
/ Steiger Super Wildcat #5
My neighbor has a Super Wildcat powered by a Cat 3160 diesel. He farms about 200 acres of hay and uses the Steiger to pull a 15-ft offset disc for primary tillage.
Good luck and post photos of your new toy.
Steiger Super Wildcat steering problems Saga continue's, original symptoms - - the tractor starting going whereever it wanted to, I had no control over the steering. When I would shut it down, it would steer correctly for about 1 minute, this is how I got it back to the shop. Solution ( 1st of many) change hydraulic oil (oil was a thin as water) and filter, problem got worse, now the steering wheel was hard to turn. 2nd solution - remove steering cylinders and check with air pressure, 1st cyclinder checked out good, held 100 psi without bleed off. 2nd cyclinder had bleed off (YAA) this must be the problem. Took cylinder apart and the square o-rings where more of a triangle shape, went to the tractor store to buy a seal kit. Tractor store wants $100 for a seal kit, no way I'm paying that, ordered some o-rings off the internet $17 :) Put in o-rings, put cylinder back on, still won't steer. Time to increase pressure to steering valve, cranked down the adjustment on the check valve and checked pressure, 2000 pds, still won't steer. Now I'm thinking the problem is cylinder 1 or steering pump, so I took off cylinder 1, took it apart and the square o-rings looked brand new, not the cylinder. Started looking for a steering valve, $600 - $1100 cost, found a NOS on e-bay for $265 with shipping, put it on, still no steering. Must be the o-rings I put in cylinder 2, I thought. Pulled off cylinder 2 checked o-rings, they're good as can be, tried turning steering wheel with cylinder off. It would turn, but it was jerky, like it had air in line, time to check hydraulic flow from pump, flow was hardly anything coming out of pump. Checked flow at back of tractor, since its a 2 stage pump, remotes had good flow. Do I need a new pump now?
I'm surprised to hear that yours shifts easy, my steiger will shift sometimes when its moving(very seldom:mad:), but usually I have to shut it down and then start the engine with the tractor in the gear that I want. Maybe my clutch needs adjusting?:laughing:
I'm surprised to hear that yours shifts easy, my steiger will shift sometimes when its moving(very seldom), but usually I have to shut it down and then start the engine with the tractor in the gear that I want. Maybe my clutch needs adjusting?
/ Steiger Super Wildcat #10
Shifts beautiful , as you will see in my pics i haul semi trailers with hay behind it . And why i use it on the dirt scraper as it will shift up to travel and dump to box then back into low to fill the box. I do like verstiles a lot more but shifting with them is more of an almost stationary job !
Bearcat will shift up the gears on the road like a truck !
I'm starting to get the hang of shifting this tractor on the move, seems like you need to keep the rpm's up when shifting. Can you tell me how many gallons of diesel you tractor burns per hour when pulling your scraper. Thanks
/ Steiger Super Wildcat #12
Never really worked it out sorry ! Scraping uses a lot less than steady pulling on a 24ft chisel plough all day .
/ Steiger Super Wildcat #13
View attachment 224315View attachment 224316View attachment 224317
Hello, my names Jake and I've recently been looking for a good Steiger Super Wildcat, to use as a parts tractor for the one i have, it seems like these things are just impossible to find, and since you were able to find one i was wondering if you could possibly know where another is. These tractors are so well built i believe, that id hate to get a different used tractor to replace it so it would be very helpful if you could give me any information on one. Thank you
I have seen a couple come up on auction sites Purple Wave and Big Iron, and there are tractor salvage yards that have parts - - but they seem high to me. I checked on a rear axle at a salvage yard and he wanted 1500 for it, that's a high price for it to go on a 4500 tractor.
I will keep me eye's open and let you know if I see one come up - -
Jake - - Be sure to check the bolts holding the rear axle to the frame (4 on each side), mine sheared off and allowed the axle to spin, breaking the pinion gear off. While replacing it I noticed that it had been replaced before, so the same thing happened to previous owner. The top of the bolts are hard to get to and hold while tightening, you need a special wrench. I have two of these wrenches if you need one.
I wish someone would have told me this, replacing bolts is a lot easier than replacing the rear end.
/ Steiger Super Wildcat #16
Wow, i actually found a bolt broken on the left side of the rear axle, i didn't think it was a common problem ill have to check on it more often. The bolts on my steiger are all regular bolts, but that could be because it got restored a while back. Thanks for the heads up.
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
Bobcat 72" Rotary Cutter (A64047)
Bobcat 72" Rotary...
2022 FORD F-750 SUPER DUTY DUMP TRUCK (A63276)
2022 FORD F-750...
2001 Freightliner FLD120 T/A Sleeper Cab Truck Tractor (A61573)
2001 Freightliner...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
BUSHHOG 2615 LEGEND BATWING MOWER (A63276)
BUSHHOG 2615...
