CK 20 HST surges
/ CK 20 HST surges #1
Iron Art
ck20hst kioti
My CK20HST with 250 hrs on it surges while going forward in low, this problem appears to be in the Hydrostat. The problem dosn't occur while backing up. The condition exists thur-out the engine speed range but is less of a problem with the tractor operating under load. Once again, the engine is operating at a steady state. Any ideas? should I be concerned? Fred
/ CK 20 HST surges #2
I have a 2008 CK20HST and mine does the same thing till the fluid warms up then it is fine. Mine only does it in low range when cold. Check your fluid lvls maybe they are low.
/ CK 20 HST surges
My tractor is a 2007/08 and has the same symtons as you mentioned except it dosn't go away with wamup. Fluid levels are fine. Thanks, Fred
/ CK 20 HST surges #4
Other than low hydro fluid, you have probably done your first service and changed the hydro fluid. The Kioti recommended oils are a 10w-30 weight. If the problem seems to go away after the oil is warm, maybe the oil you're using is to heavy a weight or a straight weight. Just a thought.
/ CK 20 HST surges #5
10W30 oil in the hydro? I don't believe that's right book says Hydraulic/Transmission Fluid.
/ CK 20 HST surges #6
The Kioti recommended hydraulic/transmission fluid/oil is a multiviscosity 10w-30 hydraulic/transmission fluid/oil for gears, brakes, and common sump and not a straight weight hydraulic/transmission fluid/oil. Being that they were talking about the hydrostatic transmission and I called it hydro fluid/oil, I believed that they would understand and not use engine rated oil in the hydrostatic transmission. I will be more specific next time.
There is also a 5w-30 hydraulic/transmission fluid/oil that some find useful in the great white north for the very cold Winter temperatures. It can be found in either synthetic or non-synthetic.
/ CK 20 HST surges #7
Surging could be caused by burnt fluid or filters that need to be changed. If you don't know the history of the oil I would be changing both first up.
/ CK 20 HST surges
My tractor book supplied with the purchase of the tracor recomends "Mobil fluid 423 or 424" or "Exxon Hydraul 560". How does this fit in with your remendations. The existing fluid and filters are good and show no signs of burned oil. Fred
/ CK 20 HST surges #9
The fluids you mentioned are listed via Kioti along with these others: Shell Donax TD, Texaco TDH oil, Exxon Torque Fluid 56, Pennzoil Hydra Tranz, BP TracTran UTH, Citgo Mystik JT-5 Universal. I've had good luck using the Shell oil in my CK30hst. Did it start surging all of a sudden, after service, after some hard use, or something else you can possibly relate it to?
/ CK 20 HST surges
Victor, Are these muti vicosity hydraulic fluids that you have listed? I am considering changing the hydraulic fluid again, and filters, would like to take the two filters apart for inspection. On the hundred hour service, I found a pc of metal on the magnetic drain plug that appeared to be a piece of spalled gear(1/4"x3/16"), but could have been part of the machining process too. (Wishful thinking) Fred
/ CK 20 HST surges #11
Did you save the piece of metal that you found at 100hr svc.?
IMHO, I would contact your selling dealer and bring it to their attention. If you have the piece you found show us a pic and show it to the dealer too.
/ CK 20 HST surges #12
The Shell, Pennzoil, and Citgo are multi vis. The others I haven't checked on but I would like to think if Kioti has them recommended, I would hope they are. I would check first whatever brand you decide to use.
When I did my first service at 50 hours, I had a bunch of metal shavings on the magnetic drain plug as if from their machining of parts. Apparently they don't clean well prior to assembly. Some members have posted finding small parts such as a pin or ring clip which you would hope was just dropped during assembly. A piece as you mentioned would be worth saving and advising the dealer as Coyote mentioned. It might save you dollars if it really is from a gear and something breaks later.
/ CK 20 HST surges #13
We have found the Shell Donax TD to perform the best in the KIOTI Hydrostats. It is a multi-vis 10w30.
/ CK 20 HST surges
Thanks for the info and advice on the various Hydraulic fluids, will most likely go with the Shell Donax TD, Not sure about the fluid that is in the backhoe and it effect on switching brands. Fred
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
2009 Honda Pilot AWD SUV (A61574)
2009 Honda Pilot...
2013 KENWORTH T660 SLEEPER TRUCK (A65643)
2013 KENWORTH T660...
Denyo DCA-600SPK 500kW Sound-Attenuated Diesel Generator (A63689)
Denyo DCA-600SPK...
Landhonor Quick Attach Tree Puller (A66285)
Landhonor Quick...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
