Got temped by HF today
/ Got temped by HF today #1
crazyal
Super Member
Northern Vermont
Kubota, Case, Deere
Well they got me, lol. They have a cheap chain sharpener, was somewhere around $40 if I remember correctly. Well today it was $19.99. I have files that cost more than that. I probably threw away $20 bucks but who knows. I'll get a chance to try it out next week.
/ Got temped by HF today #2
I think as long as your safety glasses,band aids and gloves do not come from HF you'll be allright. :D
Boone
/ Got temped by HF today #3
This one is in the plyer now for 19.99
Electric Chain Saw Sharpener
But even the 24 dollars isnt a bad price I got it a few years ago and paid close to 100 dollars
but now in northern there is a better one for 100 dollars..lol
Anyways ive had that one for five years.I bought extra wheels but havent changed one out yet..Its not precise but its not bad at all...
good luck..
/ Got temped by HF today #4
I'm sure these things work well, but I've never understood the advantage. I use the Dremel attachment. It works great and only takes a couple of minutes to sharpen a chain because you don't have to take it off the saw.
/ Got temped by HF today #5
wish I had a dremel I would have used that and not gottent he other one.. I usually file a few times inbetween the machine..the machine lets you get the angle back .. expecially if your eye sight isnt what it used tobe..I the 99 dollar one from northern.
http://www.northerntool.com/shop/tools/product_200327449_200327449
Just sharlened one chain and couldnt believe how sharp it was... this is a better unit than the HF one..
Up until now I used a Dremel as well. I use thread cutting spray lube. It's worked just fine and you don't need to pull the chain to use it. I've often looked at the Oregon clamp on sharpener but at about $200 it's kind of pricey when I only sharpen a chain less than a dozen times a year. The problem the the Dremel is I don't pull the bar as often as I should to clean out the oil passageways. So I may have thrown money away and I may not use it very much but it was so cheap. :laughing:
/ Got temped by HF today #7
Northern Industrial Bench- or Wall-Mount Saw Chain Sharpener | Chain Saw Sharpeners, Maintenance + Repair | Northern Tool + Equipment
I am looking at that same one from Northern. Told my wife that I wouldn't mind it as a Christmas gift. Just hoping the 4 chains I have for the MS261 get me to Christmas. Hit the dirt twice yesterday and now the chain is cutting 1/2 as good as it used to. Then again, I have cut 2 cords of wood with it.
I think I am going to go with 5 or 6 chains per saw and just sharpen a group of them altogether when I get down to the last one or two sharp chains. Kind of like reloading shotgun shells and metallic cartridges. If you are going to sit down at the machine, you might as well make it worthwhile and reload a bunch.
/ Got temped by HF today #8
Well if the budget allow you wont be disapointed in the northern one.I only wished it was aval back when I got my HF one.I use the northern to sharpen and I also ran some dirt but a slight filing and it brought it back,
/ Got temped by HF today #9
My neighbor has the HF one and it has worked well for him.. He doesnt cut professionally so it only see intermittent usage..
Brian
/ Got temped by HF today #10
hey, I just sharpened my first chain on mine. I looks pretty good. Hope it cuts on the saw.:thumbsup:
mf
/ Got temped by HF today #11
I have the Northern Tool version and am very happy with it. It's in a neighbor's barn and we using as a community tool. There is much word in these parts that the HF version has too much slop in it to be of any use.
As a note, the angles that NT recommends (60 degrees) are a bit off. We've had great success with 50 and 55 degrees for a better cut.
If you're investing in a sharpener, don't forget to attend to your rakers (depth teeth). My chains just went past the 50% point and I got significantly better performance by taking the rakers down to 0.025". Use the tool, and get a proper raker file since a ******* file a) won't work, and b) the side teeth will chew up your cutting teeth.
/ Got temped by HF today #12
At the minimum, I am getting the Northern Tool version. Have been debating the older model of the Oregon one, the Model 510. Northern Tool has that one for $200. Thing is, I am only cutting wood to run my wood furnace and possibly a wood burning insert if my dad ever decides to get one. Might eventually be cutting wood for a wood stove or two if we put in the addition we are thinking about. Can't imagine that I would have more than a couple chains a year to sharpen. My problem is that I am like Tim Allen on tool time. Uh, Uh, Uh. Always got to buy some of the most expensive equipment out there to make the job easier and more pleasurable. I've even got a Stihl dealer looking into the price of a Stihl electric sharpener. Ultimately, I think I am going to go with the Northern Tool house brand one because I am also cheap and don't really see the benefit of going with a $200+ sharpener.
/ Got temped by HF today #13
I've had mine for years. Hardly use it as I can sharpen one using my Oregon clamp on file guide and sharpen them faster ...about 10minutes which include the time to mount saw in vice and the mount the guide. Using the HF one I have to be careful and slow to keep from overheating the cutters.
Still do use the HF to straighten out a badly 'rocked out' chain.
Harry K
/ Got temped by HF today #14
i bought mine at hf last year i think it was 39.00 i am very happy with it.i used to take mine in to have it sharpened and i would watch them so i knew what had to be done.it works fine for me.i know a lot of people that have them and they are happy
/ Got temped by HF today #15
If you get the HF one, get better wheels from Oregon. The corundrum with sharpeners (grinder type) is that the cheap ones are marginally ok for occasional use but they spin too fast, have little torque and burn the chain. Their shafts get sloppy because they are weak with little support and they may or may not hold the chain tight. Soon you have a $39 piece of trash if you sharpen more than once a week. If you use a $300 one you'd see the difference and supports the notion that ignorance is bliss. The problem there is that few people are willing to shell out that kind of money for the "occasional use" but settings are more precise, they run smoother and you actually get a sharpened chain. The $100 one from Northern may be a compromise between junk and halfway decent but my recent sharpener ( not from Northern) cost $169, is just ok, and cannot compare to the one I used to have for the same price 35 years ago that now costs over $300. It all depends on your temperment and preferences of what one values most between money spent and quality of job that the tool does.
I've only picked up the chainsaw twice this year and I think the last time I sharpened a chain was in October of last year. I tend to be like fabsroman and over buy when there's no reason to. Or I want to over buy and spend too much time thinking about it (knowing I really don't need as nice of a model) and not buy at all.
I found if you use a pipe thread cutting spray it keeps from burning the chain and killing the temper. I thought about breaking out the sharpener today but it was in the mid 80s and too hot for me.
/ Got temped by HF today #17
Getting what's called a "Koolstik" may be handier to mitigate chain burning.
(6) 250 Gallon Chemical Totes (A64127)
(6) 250 Gallon...
Luck Now 425 (A64126)
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
Kubota Snow plow with subframe
Kubota Snow plow...
2007 Chevrolet Silverado\ Silverado Classic Pickup Truck, VIN # 1GCEK14X27Z181945 (A61165)
2007 Chevrolet...
2000 Ford Windstar Van (A61574)
2000 Ford Windstar...
