Paint for Trailer
/ Paint for Trailer #1
94BULLITT
Super Member
USA
yes
My trailer needs painted. It is a car trailer with diamond plate runways. What wound be a good type of paint to use as far as durability and something that the uv rays will hold up to. I am thinking of painting it gloss black.
/ Paint for Trailer #2
I used some paint from Tractor supply, I think it was called Truck and Trailer paint or Implement paint, if you do use this paint be sure to put a hardner in it, its makes it shine better and helps from rock chips, after about 3 years it still held good color, had to paint a few places here and there, but that was from the way I used the trailer. Good luck
/ Paint for Trailer #3
I second the implement paint. I have also used Rustoleum with fair results. Just spray it with a compressor on a calm day.
Chris
/ Paint for Trailer
I wondered how well that tsc trailer paint would hold up. Do you keep your trailer outside?
/ Paint for Trailer #5
After I painted this trailer I keep it for 3 years before selling it, the paint held up good, just had to keep it touched up from normal wear from chains and tie-downs, other than that it held its color. Reason for selling was I needed a longer and more heaver axles, I went from 2 7K's axles to 2 12K axles.
I keep it inside and outside, hard to tell if the sun faded the color or not.
/ Paint for Trailer #6
I agree to use Rustoleum or Implement paint. I have to paint my trailers about every 3 years. Mainly that is because I tow them at times in winter and roads here are salt covered. The factory paint on my 06 trailer (bought in Sept. 05) lasted about 3 years so I decided to repaint. The first time I painted it (in 08) I applied the paint with a spray gun and used Implement paint. This spring (2011) I used Rustoleum and brushed it on. Will have to wait a couple years to see if it lasts. You shouldn't have the road salt problem where you live so a re-paint should last longer.
/ Paint for Trailer #7
while we are on the topic of painting trailers- how much paint does a 8 ft trailer take? 16 foot? quart? gallon? how much did you guys use on average?
/ Paint for Trailer #8
I used about 1-1/2 to 2 quarts to paint my 20' tilt bed with a brush. It was about the same spraying it 3 years ago using several coats. The 24' gooseneck also used about the same.
My 5 x 8 trailer only took about 1/2 quart or so using a brush. Same with my neighbors 6 x 12.
All the trailer have wood decks that were not painted.
/ Paint for Trailer #9
Last 16' trailer I painted took 2qt. Just did the metal frame, and mesh gate. Did not do the wood deck.
Chris
/ Paint for Trailer
I went to 3 tractor supply's saturday and none of the had the truck and trailer paint. Now am not sure what I am goin to do.
/ Paint for Trailer #11
Use farm implant paint. That is what I use. Tough as nails.
Chris
/ Paint for Trailer #12
It might of been implement paint, I bought some truck and trailer paint somewhere, Just thought it was tractor supply. That the only place I buy paint from.
/ Paint for Trailer #13
I call TSC in advance and they can usually get whatever I need within a few weeks if not sooner.
/ Paint for Trailer
They show it on the sign that describes what kind a of paint to use for what but the do not stock it.
Chris
I may end up using that.
I ordered lift arms for my 8n 2 winters ago because I bent them pushing snow. They were supposed to have them shipped in from a near by store and they would be in a few days, a month later I had not heard a thing. One day I went in and they had a set back on the shelf so I got them and they never did call me. Also I special ordered a tool box for my truck and it was supposed to be in 2 weeks but it was a month coming in. So I don't want order paint and it be forever coming in or never get it. I ordered a tool box for the trailer from harbor freight and it was in stock when I ordered it. Now it is on back order til October, so that is holding me up on this project some but at least I can paint it.
/ Paint for Trailer #15
I just painted my 24'+5' dove tail & ramps. I did it while I was replacing the floor so I painted cross members, inside the frame and all. I was also changing color, so that took a little more paint. I used 2 gallons of Rustoleum. The trailer was black, and I changed it to "safety red", which looked more like safety orange for a few days. ?????:confused2: It finally darkened a little into a really bright red. Looks ok with the new floor.
Andy
2023 KMC 3pt 6 Row Rolling Cultivator (A64119)
2023 KMC 3pt 6 Row...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
211453 (A62131)
211453 (A62131)
2023 BOBCAT T66 R-SERIES SKID STEER (A62129)
2023 BOBCAT T66...
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
2006 Honda Odyssey Van (A61574)
2006 Honda Odyssey...
