Paint for Trailer
/ Paint for Trailer #1
94BULLITT
Super Member
USA
yes
My trailer needs painted. It is a car trailer with diamond plate runways. What wound be a good type of paint to use as far as durability and something that the uv rays will hold up to. I am thinking of painting it gloss black.
/ Paint for Trailer #2
I used some paint from Tractor supply, I think it was called Truck and Trailer paint or Implement paint, if you do use this paint be sure to put a hardner in it, its makes it shine better and helps from rock chips, after about 3 years it still held good color, had to paint a few places here and there, but that was from the way I used the trailer. Good luck
/ Paint for Trailer #3
I second the implement paint. I have also used Rustoleum with fair results. Just spray it with a compressor on a calm day.
Chris
/ Paint for Trailer
I wondered how well that tsc trailer paint would hold up. Do you keep your trailer outside?
/ Paint for Trailer #5
After I painted this trailer I keep it for 3 years before selling it, the paint held up good, just had to keep it touched up from normal wear from chains and tie-downs, other than that it held its color. Reason for selling was I needed a longer and more heaver axles, I went from 2 7K's axles to 2 12K axles.
I keep it inside and outside, hard to tell if the sun faded the color or not.
/ Paint for Trailer #6
I agree to use Rustoleum or Implement paint. I have to paint my trailers about every 3 years. Mainly that is because I tow them at times in winter and roads here are salt covered. The factory paint on my 06 trailer (bought in Sept. 05) lasted about 3 years so I decided to repaint. The first time I painted it (in 08) I applied the paint with a spray gun and used Implement paint. This spring (2011) I used Rustoleum and brushed it on. Will have to wait a couple years to see if it lasts. You shouldn't have the road salt problem where you live so a re-paint should last longer.
/ Paint for Trailer #7
while we are on the topic of painting trailers- how much paint does a 8 ft trailer take? 16 foot? quart? gallon? how much did you guys use on average?
/ Paint for Trailer #8
I used about 1-1/2 to 2 quarts to paint my 20' tilt bed with a brush. It was about the same spraying it 3 years ago using several coats. The 24' gooseneck also used about the same.
My 5 x 8 trailer only took about 1/2 quart or so using a brush. Same with my neighbors 6 x 12.
All the trailer have wood decks that were not painted.
/ Paint for Trailer #9
Last 16' trailer I painted took 2qt. Just did the metal frame, and mesh gate. Did not do the wood deck.
Chris
/ Paint for Trailer
I went to 3 tractor supply's saturday and none of the had the truck and trailer paint. Now am not sure what I am goin to do.
/ Paint for Trailer #11
Use farm implant paint. That is what I use. Tough as nails.
Chris
/ Paint for Trailer #12
It might of been implement paint, I bought some truck and trailer paint somewhere, Just thought it was tractor supply. That the only place I buy paint from.
/ Paint for Trailer #13
I call TSC in advance and they can usually get whatever I need within a few weeks if not sooner.
/ Paint for Trailer
They show it on the sign that describes what kind a of paint to use for what but the do not stock it.
Chris
I may end up using that.
I ordered lift arms for my 8n 2 winters ago because I bent them pushing snow. They were supposed to have them shipped in from a near by store and they would be in a few days, a month later I had not heard a thing. One day I went in and they had a set back on the shelf so I got them and they never did call me. Also I special ordered a tool box for my truck and it was supposed to be in 2 weeks but it was a month coming in. So I don't want order paint and it be forever coming in or never get it. I ordered a tool box for the trailer from harbor freight and it was in stock when I ordered it. Now it is on back order til October, so that is holding me up on this project some but at least I can paint it.
/ Paint for Trailer #15
I just painted my 24'+5' dove tail & ramps. I did it while I was replacing the floor so I painted cross members, inside the frame and all. I was also changing color, so that took a little more paint. I used 2 gallons of Rustoleum. The trailer was black, and I changed it to "safety red", which looked more like safety orange for a few days. ?????:confused2: It finally darkened a little into a really bright red. Looks ok with the new floor.
Andy
Colombo CTA 6500 (A64119)
Colombo CTA 6500...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
1660 (A59213)
1660 (A59213)
2006 Chevrolet Silverado 2500HD Ext. Cab Knapheide Service Truck (A61573)
2006 Chevrolet...
2006 Mack CV713 Flatbed Truck (A62679)
2006 Mack CV713...
2005 Kubota L3130 (A60462)
2005 Kubota L3130...
