Mowing mowing a 10 acre field
/ mowing a 10 acre field #1
bgreenwald
john Deere 4420
What is the best implement to mow a 10 acre field that has rough terrain, rocks. I own a jd 4420 and am not sure which type of implement is best and what size.
/ mowing a 10 acre field #2
A rotary pasture mower referred to as a brush hog.
/ mowing a 10 acre field #3
6-ft wide rotary mower (aka brush hog, bush hog, shredder, slasher). Mine is a 6-ft Hawkline that cost about $1150 when I bought it 3 years ago.
/ mowing a 10 acre field #4
How much money do you wanna spend? You've got some horsepower to work a pretty big rotary mower - 10'-15' - if you want to go that route.
If you want to avoid as many obstacles (rocks, etc. as possible; I'd be looking for a semi-mount mower with hyd lift on the rear wheels.
You can start out mowing "high" until you know more about things to look out for and mow a little closer after the initial once over.
AKfish
/ mowing a 10 acre field #5
Go with the(Rotary cutter) pull-type 8ft or better!!! Cuts down on your mowing time and I put ours threw alot, just make sure you get the HD or better!!
/ mowing a 10 acre field #6
I agree with a brush hog as the tool but rocks and mowers can create a dangerous situation. Mowers can shoot rocks like bullets so be careful if it isn't possible to eliminate most of the rocks prior to mowing.
MoKelly
/ mowing a 10 acre field #7
MoKelly
I agree make sure the shredder has chains!!
/ mowing a 10 acre field #8
Not trying to nit-pik here but I need some explaination or clearity on your model of tractor... The only 4420 Deere I know is a Combine, it concerns me than others on this page reccomend a 8-10 foot cutter, eloborate on what this would be based on.. A 4430 or 4440, would be north of 120 pto h.p. and being a tractor, capable of pulling a 12-15 foot rough mower..
/ mowing a 10 acre field #9
I was saying 8ft or better,once you get into the larger (flatdecks)you start having gate problems(no fit) or you get into batwings with more cylinders and stuff to up keep. Im not against 15ft batwings wish I had one!!!!
/ mowing a 10 acre field #10
Specs on 4420
TractorData.com John Deere 4420 tractor information
/ mowing a 10 acre field #11
Would you not want to fix the rough terrain, rocks first before you consider mowing?
KOMATSU FORKLIFT (A63291)
KOMATSU FORKLIFT...
PALLET OF TRACTOR WEIGHTS (A64278)
PALLET OF TRACTOR...
2025 SDLANCH SDL2030GT Heavy-Duty Greenhouse Tent (A64194)
2025 SDLANCH...
2025 60in Bucket Skid Steer Attachment (A64553)
2025 60in Bucket...
2011 JOHN DEERE 672G MOTORGRADER (A63276)
2011 JOHN DEERE...
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
