Lots of black smoke on B7800
   / Lots of black smoke on B7800 #1
Buster57
Hillsboro, Oregon
B7800, JD RX95
At 180 hours I switched from standard to synthetic Mobile One oil and now have lots of black smoke. I am up to about 205 hours and it seems to be getting worse.
The performance is unchanged-excellent-it just smokes like crazy. Any time it is under a load it smokes. I have never had this happen before.
Any suggestions on what to do? I can take it to the dealer but I want to do that as a last resort.
Maybe injector cleaners? I am clueless.
Thank you!
   / Lots of black smoke on B7800 #2
Thank you!
First thing I would do is check the air filter to be sure it's clean, and make sure no 'varmints' stored food in the air intake system.
The oil change may just be a coincidence.
I checked the air filter-it was gross.......I can't believe I let it get so bad...
I will have to wait until Monday to get another one but that is definitely part of the problem.
Thanks!!!
   / Lots of black smoke on B7800 #4
I assume you bought diesel oil...
   / Lots of black smoke on B7800 #5
Black smoke is a rich fuel mix. The crankcase oil can burn like fuel oil if it gets into your intake path, or into the cylinders.
I've run synthetic oil in my B7800 since the second oil change without problems, but if you've got a bad valve seal, or routed crank breather fumes into the intake like in a pcv system this could happen, I guess.
But if your air filter is clogged that's the most probable reason, I think.
I bought Mobile One at Costco 5W30.
I think the problem has been solved. I will have to check the air filter (NAPPA for $35...) more frequently.
Beez perhaps you can explain to us exactly what 'diesel oil' is?
Thanks again!
   / Lots of black smoke on B7800 #7
Thanks!!!
Your welcome.
   / Lots of black smoke on B7800 #9
I didn't realize you put gasoline engine oil in(good catch BeezFun)............Change to diesel oil ASAP, and replace the air filter.
The Kubota dealer had no probelm at all with me using Mobile One as engine oil.
Maybe you guys know more then we do. Please explain again so I can double check with Kubota.
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
2022 KUBOTA SVL75-2 SKID STEER (A51242)
2022 KUBOTA...
White 2-55 Loader Tractor (A50514)
White 2-55 Loader...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2015 FREIGHTLINER...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
SAKAI SW502S-1 SMOOTH DBL DRUM ROLLER (A51242)
SAKAI SW502S-1...
