Lots of black smoke on B7800
   / Lots of black smoke on B7800 #1
Buster57
Hillsboro, Oregon
B7800, JD RX95
At 180 hours I switched from standard to synthetic Mobile One oil and now have lots of black smoke. I am up to about 205 hours and it seems to be getting worse.
The performance is unchanged-excellent-it just smokes like crazy. Any time it is under a load it smokes. I have never had this happen before.
Any suggestions on what to do? I can take it to the dealer but I want to do that as a last resort.
Maybe injector cleaners? I am clueless.
Thank you!
   / Lots of black smoke on B7800 #2
Thank you!
First thing I would do is check the air filter to be sure it's clean, and make sure no 'varmints' stored food in the air intake system.
The oil change may just be a coincidence.
I checked the air filter-it was gross.......I can't believe I let it get so bad...
I will have to wait until Monday to get another one but that is definitely part of the problem.
Thanks!!!
   / Lots of black smoke on B7800 #4
I assume you bought diesel oil...
   / Lots of black smoke on B7800 #5
Black smoke is a rich fuel mix. The crankcase oil can burn like fuel oil if it gets into your intake path, or into the cylinders.
I've run synthetic oil in my B7800 since the second oil change without problems, but if you've got a bad valve seal, or routed crank breather fumes into the intake like in a pcv system this could happen, I guess.
But if your air filter is clogged that's the most probable reason, I think.
I bought Mobile One at Costco 5W30.
I think the problem has been solved. I will have to check the air filter (NAPPA for $35...) more frequently.
Beez perhaps you can explain to us exactly what 'diesel oil' is?
Thanks again!
   / Lots of black smoke on B7800 #7
Thanks!!!
Your welcome.
   / Lots of black smoke on B7800 #9
I didn't realize you put gasoline engine oil in(good catch BeezFun)............Change to diesel oil ASAP, and replace the air filter.
The Kubota dealer had no probelm at all with me using Mobile One as engine oil.
Maybe you guys know more then we do. Please explain again so I can double check with Kubota.
2021 CATERPILLAR 299D3 SKID STEER (A51242)
2021 CATERPILLAR...
1996 PETERBILT 357 35 TON WRECKER (A50505)
1996 PETERBILT 357...
2007 Peterbilt 335 Mickey AO-A Battery Truck (A50323)
2007 Peterbilt 335...
2013 Acura ILX Sedan (A50324)
2013 Acura ILX...
1994 FORD F450-SUPER DUTY FLATBED (A51222)
1994 FORD...
New 4-17.5 Forerunner Skidloader Tires (A50774)
New 4-17.5...
