Building a 30x50x16 pole barn
/ Building a 30x50x16 pole barn #1
mfairbank
Member
Im building this barn is there any tricks to getting the header aligned and straight. Or any other possible problems that i might run into down the road. This is my first barn i have ever built and any input would be greatly appriciated
Thanks
/ Building a 30x50x16 pole barn #2
Take your time and measure, measure and mesure. I'm building one too but mine is metal on concrete.
/ Building a 30x50x16 pole barn #3
Start putting your wall purlins on keeping the posts plumb as you go. Go get a few rolls of "masons twine" for straight lines. These lines will not lie to you!
Use your level and string lines as you progress up to the top where your header will be. When using a string line I like to space it out where you fasten it to the corners (usually with a 2x4) off the post so that you'll need an equal thickness "guage block" to check your wall. You can move the string up with your work.
With everything as square and level as you can get it, get a good dimension that is the top of the header across to the other side (where your trussus will sit) This might have to be an average of the entire legnth of the wall, but if your real good the number will be the same the entire legnth.
Now line your trusses up on the ground, flat, so that all the edges are in line and mark your wall dimension that you measured earlier on to them. Wether you mark them at the outside of the beam (header) or the inside, it doesn't matter just as long as it is where you measured to. If you can, set about 3 or 4 at each end paying close attention to your marks, tie them togher (each group) and brace them off well, and put a string at the "tails" of these across the whole wall. From this point you can set to the string or use both the string and the marks. Every now and then have the good look at your progress and watch the truss peak, overhangs etc. Your eyes won't lie either! Take your time and be safe, I will not try to describe it here but look online or some where (the trusses should come with bracing instr.) to find out how to properly diagonally brace your trusses. Be sure that you have enough 2x4x16 around, you'll be suprised you could go thru 30pc real quick.
You may want to have a few guys there that do this for a living. good luck!
/ Building a 30x50x16 pole barn #4
Just finished 52x20 pole barn. You can do it.
Thanks for all the tips....I have concrete being poured friday so i will have more pictures to come.
What is the maximum distance i can space my girts for my walls?? I was gonna do it at 24" on center but if i can get away with a little farther spaceing to save me some money on the lumber i will do that....just looking for any way to save me some money but still have the strength of a expensive barn
/ Building a 30x50x16 pole barn #6
I would keep them at 2' centers up to 8' wall height just for the additional stregnth down where things may get bumped, you may find that you want to (later) add either a 4' or 8' lining of 4x8 OSB or plywood for a liner on the inside depending on your use. Above that I don't think that 32" would be stretching it too far.
/ Building a 30x50x16 pole barn #7
I usualy set blocks for the header to sit on, they are put on using a laser so I know they are straight. I built a small bracket out of 2" angle iron that has a little jib on it, it anchors to the top of a pole, I then hook the winch cable to the jib and winch one end up, then the other unless the beam can be lifted at the center fairly easy.
I gonna be using a 2x10 for the header.... So i will have to measure up 16 foot from the top of the skirt board make a mark then measure down the post 10 inch or 9 3/4 inch and nail a 2x6 to the post so the header can have something to rest on while im nailing the header up. Because i would think nailing a 2x10 16 feet in the air will be kinda hard to get level.
/ Building a 30x50x16 pole barn #9
yup, sounds about right. I build them with the help of lasers. How close are the posts? I'm not sure 2 x 10 would fly here unless the posts are close and you put them inside and out.
The posts are spaced different spacing for each one to align for the trusses... THe farthest post spaceing is 12 foot. I will have double trusses sandwiched on each side of the post so the header shouldn't be holding much weight.
/ Building a 30x50x16 pole barn #11
why would you space the trusses that far apart? I know some of the "kits" they sell around here have trusses on 4' centers, I will not build that way, I put trusses at 2' centers. for one they are easier on me to straddle while putting them up and secondly, the homeowner usualy will want to put some sort of ceiling up down the road.
I didn't even look to see where you are located but here we have heavy snow loads.
/ Building a 30x50x16 pole barn #12
pretty sure my dads pole building has a 10' spacing on trusses, but they did double trusses at each one with a 6" space for the poles. It holds up to harsh montana winters, but the metal roof also helps keep the snow from building up too much. 2' would be for genral stick built buildings, but doesn't apply at all for pole buildings where you have runners as supports for the roofing material.
Yea im using double trusses that go on each side of every 6x6 post. The farthest space is 12 feet and the rest are about 5' 3' 8.5'. so it should be pretty sturdy after i get all the trusses and girts up.
2005 Kubota L3130 (A60462)
2005 Kubota L3130...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
2019 MACK ANTHEM 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 MACK ANTHEM...
2017 Chevrolet Cruze Sedan (A61574)
2017 Chevrolet...
60" EXCAVATOR RAKE (A64279)
60" EXCAVATOR RAKE...
2008 Kaufman Wedge Trailer (A62613)
2008 Kaufman Wedge...
