3-Point Hitch Missing lift arm ball!
/ Missing lift arm ball! #1
KenPauling
Northcentral PA
Now Holland TN 65D with Cab
This is strange. I went to put on a 3 point hitch attachment on my TN65D and noticed something was missing! The ball at the end of one of my lift arms was gone! Anyone ever have this happen to them? I have had trouble finding a replacement ball and only an aftermarket one was available in my area! The exact size retaining pin has been impossible to find. Even the local New Holland dealer didn't have one. He said it took a metric pin and he didn't have any.
/ Missing lift arm ball! #3
Ken, Oh Yea, the balls fall out... :eek: Pricey little buggers to... There should be a keeper spring on the outside of the lift arm that keeps the balls in place. Open the spring, turn ball to flat spot, and will lift right out. (or bounce out by its self) on mine the spring got week and wouldn't keep the ball from falling out. I had to keep a pin thru hitch. Balls come in cat 1, and cat2 and is the reason for being able to replace. Check out the other side, and should find the spring. At least that is how mine work. Good luck.
I think the keeper pin got weak or was defective and fell out. This let the ball rotate to the position which it just falls out. The story isn't over! I called corporate New Holland on their new "one call for all" hotline when I couldn't get a new ball or keeper anywhere locally. They were very nice and promised to find out where I could get a new ball and keeper pin that will fit. I have been waiting since Saturday! I'm glad, I don't make a living farming. It seems something as simple as a lift ball and pin is taking corporate NH days to find!
/ Missing lift arm ball! #5
I thought I was the only person this happened to. About a year ago I went out to hook up the brush hog and crap.... I'm missing one of my balls :laughing:. Luckily I called my NH dealer and he sent me one pronto.
/ Missing lift arm ball! #6
This has happened to me. The balls are avaiable at most equipment dealers and they cost about $5 each. the pin or retaining clip is another story. You may have to get that from CNH.
/ Missing lift arm ball! #7
The hitch balls on TN tractors are different from the old Ford hitch balls on Thousand series and other models. You are not likely to find what you need at TCS, Rural King or whatever. But you don't need to get dramatic, any New holland dealer can get both the ball and clip overnight if you want to write the check for shipping, or within less than a week on stock order, freight free. A well-stocked dealer will have both cat I and cat II balls on the shelf, I know I do. The retainer clip is of metric dimension, but can easily be crossed over to a generic small hairpin clip by means of a simple visual comparison of the remaining clip on the other arm to the various sizes of hairpin clips hanging on the wall at the store.
Hi RickB! I didn't mean to get dramatic but my local dealer couldn't find any reference or diagram in his books on the ball I needed! I gave him my tractors serial number and series number and still no luck! I agree it should be a simple "I"ll order you one and it will come in a a few days." So far, I've gone into 3 hardware stores, Lowes and tractor supply and have not found an exact replacement retaining clip. I found one thats the same diamater but a little short. I'm going to call Messicks today and I'm sure they will be able to help me. By the way, thanks for all your input on this forum. You help make it a great place to get help and information. Ken
/ Missing lift arm ball! #9
New Holland parts books for this model tractor are hard to follow sometimes. This is a common part lost and any New Holland Dealer should have some instock of Cat I and Cat II. The hair pin can be sub with a standard size pin anthing in the hole will keep the ball from falling out.
Maybe you will get lucky and the missing ball will sprout and you will have a bumper crop
Good Luck
I hope it sprouts without rain! My garden is just about lost, due to lack of rain in July. The good news is, I only mowed about 50 acres in the last two weeks. All I have to do is walk the 50 acres and it will be waiting for me!
/ Missing lift arm ball! #11
Good luck walking. Most of the time when lift arm balls fall to the ground they land with eyes down and therefore grow down into the ground. Rare occasion they land eyes up and sprout the next spring bearing bountiful harvest of new lift arm balls
/ Missing lift arm ball! #12
If they don't get lost in pairs, they won't pollinate.
/ Missing lift arm ball! #13
Last night, I finished raking about 90 acres of hay meadows. This morning, I noticed that one of my lift arm balls is missing on the TN70A. I've had this tractor for over 3 years and that's the first time that it's happened to me. Looks like a trip to the NH dealer. :mad:
/ Missing lift arm ball! #14
Well, good news and bad news.
The local NH dealer had one hanging on the pegboard behind the parts counter. (but, only one) Said that they're having trouble getting them in.
Bad news is they cost $25 each!
/ Missing lift arm ball! #15
Makes you appreciate the good old days when it was common to have a local machinist around that could just whip one up.
/ Missing lift arm ball! #16
Makes me appreciate the lift arms that don't have them dang little balls! :thumbsup: Cat II to Cat I bushings are cheap! ;)
Good news! If you loose your balls, after market ones are only $8.00! Lesson to be learned, check your balls often! Original ones are hard to find and expensive!
/ Missing lift arm ball! #18
Ah yeah the good old days. Dealing with a cantankerous old machinist and waiting 3 weeks for the part and going back into the shop and your old part is still where you placed it on his workbench 3 weeks earlier........
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
2025 Unused SDLGC80 Electric Golf Cart (A60352)
2025 Unused...
1995 Landoll 55 Ton Trailer (A60352)
1995 Landoll 55...
2018 Chevrolet Trax SUV (A59231)
2018 Chevrolet...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
