Had a breakdown!
/ Had a breakdown! #1
284 International
International Harvester 284
I finally had something fail due to wear and not abuse or improper assembly. My YM240 has a separate hydraulic pump to power the loader. I had left the tractor at my dad's house so he could do some cleanup. After only a few minutes he called me and said the loader wouldn't work.
A quick trip back to check things out revealed that the hydraulics for the loader weren't working at all, but the system was full of fluid. Stuck working on it away from the shop and my tools (such as they are) I tore down what I could easily access after failing to be able to drag the thing out of the spot it's in.
The problem was pretty obvious quickly: The intermediate shaft between the crankshaft and the forward mounted pump (It sits just underneath the battery) would spin, but the pump's shaft would not. A couple bolts later, I had the shaft out:
It's a really weird setup (to me) called a chain coupler. It's about 5 inches long, and is a spool shaped piece of steel with gears on the spool ends. Then, a double thickness of chain attaches one side to a sprocket on the crankshaft, and the other side to a sprocket that fits onto a keyed shaft:
The Woodruff key was quite mangled, and was the proximate cause of the pump's failure to operate.
The crankshaft side of the shaft has obviously been broken (breaking?) for awhile, and originally was captive to the crankshaft sprocket by the double-linked chain, but that is mostly destroyed. The sprocket teeth on two of the three sprockets on the shaft are SEVERELY undercut and worn (semi-visible in a couple of the photographs) beyond serviceable life.
A chain coupler gives a little bit of misalignment allowance for flex, but in this case it wore itself out. I'm not sure if it's due to excessive misalignment, inadequate lubrication (I've never lubricated it, but have under 50 hours on the machine since I've bought it) or a combination of them. I haven't pulled the pump out yet, or the crankshaft pulley, to examine them, but will take pictures as I go if people are interested in the repair.
/ Had a breakdown! #2
they do have some elaborate drive systems on some of these yanmars. my 14MkII has a double uni jointed shaft about 8" long thats on a slight offset but its worn out and wobbles badly that drives the electric PTO. very hard to get something made to replace it let alone the cost. even the drive shaft is similar and also it too is worn out and makes a h#ll of a racket when driving.
/ Had a breakdown! #4
Neat, new shafts are avaliable... They cost as much as the tractor (almost) though!
/ Had a breakdown! #5
Ouch!
The shaft on the pump could be re-keyed rather than replacing the pump by a careful person with a small cut off wheel like a dremel tool and a jig built (edit: short piece of 1/2" angle iron clamped to shaft comes to mind) to help make straight cuts that could be clamped to the shaft. The set screw in the new gear could be put down into the old worn keyway for extra holding power that would also dictate where the new keyway would be. (I know this mental pic is hard to visualize but I see it clear as a bell)
It would take some doing but with a new key handy it could be fitted pretty easily I think may take some fine tuning with a good 1/8" square file also, the gears and chain should be no big deal and get a can of motorcycle chain lube the good sticky stuff! :thumbsup: good luck
/ Had a breakdown! #6
... or just plumb the loader to the tractor's hydraulics, via the divider block under the front of the seat.
/ Had a breakdown! #7
Or cut and splice into the high pressure line like all the VN recons have.
/ Had a breakdown! #8
The US Yanmars already have a factory-installed diverter block for this. To use this you remove (install?) an allen-head plug inside one of its ports to send the fluid out/back for the new application, in series ahead of the 3-point lift. The loader on my YM240 is plumbed this way.
/ Had a breakdown!
I don't have much time to work on things at the moment, but will spend some time pulling it apart and seeing what I'm actually faced with. My strategy is first to get it out of the yard and back to my garage, so I'm not working in dirt and weeds.
I'm hoping the pump's shaft is ok. I couldn't see it, but could feel the groove for the key, and it seemed to be in usable condition.
I wonder how many thousands of hours this thing has on it to wear the chain out like this. It's going to be a fairly simple fix, but it's a nuisance to have my loader go down like this. I've come to take it for granted!
/ Had a breakdown! #10
My YM2002D has those ports also.
/ Had a breakdown! #11
Once I bought an old tractor that had a loader but it wouldn't run and I wondered out loud how we were going to move it.
The farmer just lifted the bucket with another tractor while his kid pulled on the control handle and the loader stayed up so we could put it on a trailer just in case that may help you get it home?
/ Had a breakdown!
Car Doc, that's exactly my plan to get it back, I just have to get it out of the little corner it's in right now: completely inaccessible from the front. I'm fortunate to have enough other machinery to help me, it's just going to be a parade of trips to get another tractor there and everything back home.
It's not really going to be a tough repair, which is nice. It's more of an annoyance than anything. I'll be in it nearly as much time to fetch it everything back home as I will be doing the repair, I'm expecting. Of course, now I jinxed myself....:laughing:
/ Had a breakdown! #13
Can you back it out of there with the bucket down? The bucket should just toboggan along.
Or maybe use a farm jack to raise the bucket. As CarDoc noted, once the bucket is up it should stay up. That might even be sufficient to get it on the trailer under its own power without taking a grua ('towtruck') out there.
/ Had a breakdown! #14
i have not tried Yanmar Australia to see if i can get them here. can you get them there? whats the damage ( cost:laughing: ) of both the PTO and drive shafts? if i can get a drive shaft i could make something up out of the old one for the PTO so that would reduce the costs as it is worn out in the spline. the uni's are OK.
/ Had a breakdown! #15
I think California hit the nail on the head. Use the tractors existing system. Some hose from the Farm supply store and a couple of fittings and you're done. Based on our local Rural King you could plumb this in for under $100 easily....probably considerably less and it's simple and clean. I plumbed mine by cutting the pressure line but if your tractor is set up with the diverter block it will be a quick and simple install. Sounds like 2 hoses (at R.King- 3/8" x 8' hose is $15.99 each- add or subtract a dollar per foot as needed on their hoses and 4 fittings at probably $5-$8 each). Looks like Tractor Supply has a little higher but similar prices.
/ Had a breakdown!
If I'm able to salvage the pump, I'm going to keep the system I have. If I have to replace the pump then I will plumb it to the tractor.
Living in this area has some nice things to appreciate, but the cost of living and doing business isn't one of them. I envy those who have a choice of suppliers locally for their equipment parts. I finally found a place to make a short (under a foot) hydraulic line for another machine. It ran me something like $100.
I can source components through mail-order, and will be doing so, one way or another, whether it's for the sprockets and chain or hydraulic lines.
Thanks for the input.
/ Had a breakdown! #17
The pto pump may be better than the tractor pump anyway for a loader mine sure isn't anything to brag about.
imo my loader is slow and I am the impatient type when I work maybe.
/ Had a breakdown! #18
My 2002d is slow also, ok at high rpm but slow at low rpm. I too, sometimes am impatient.
/ Had a breakdown! #19
me 3, trying to dig a hole and move slowly but needing quick hydraulics is never gonna happen with these machines:( i had the revs up but using the clutch slip and it was better but not for the poor clutch :ashamed:
/ Had a breakdown!
What you're talking about is why I want to keep the auxiliary pump. I've never had any complaints about the speed of my loader hydraulics. I don't know what the output volume of that pump would be, but it's enough to operate the loader without being slow.
2019 Toro Groundsmaster 7200 72in. Zero Turn Commercial Mower (A64553)
2019 Toro...
2014 Kenworth T370 21ft. Flatbed Truck (A64194)
2014 Kenworth T370...
New/Unused Landhonor Quick Attach 3 Point Hitch Adapter (A65583)
New/Unused...
2016 INTERNATIONAL 4300  4X2 24FT BOX TRUCK (A67147)
2016 INTERNATIONAL...
2018 JOHN DEERE 35G EXCAVATOR (A65053)
2018 JOHN DEERE...
New/Unused ATS Lifting Motor (A65583)
New/Unused ATS...
