Shed Plans
/ Shed Plans #1
MillWeld
Gold Member
Durham NC
Ford 641
I am helping build a 12 x 12 studio/shed for a friend. Does anyone know of a source of free plans for such?
/ Shed Plans #3
These plans aren't expensive--$15-25. I built this 10x12 ft saltbox storage shed from store bought plans after looking for decent free plans unsuccessfully.
/ Shed Plans #4
What do you want for a foundation and floor?
- Poles, with gravel or slab floor
- Beams on sonotubes or blocks, with a wood floor on the beams
- Floating Slab (slab-on-grade)
- Poured footer and stacked block, with either a wood or slab floor.
These all have advantages and disadvantages for ease of building, durability, and cost.
Is this going to be insulated and finished on the inside?
If so, it's really hard to beat stick framed for cost...though if you're in a termite-prone area, you might have to switch to pressure treat or steel studs.
If not, then pole-building style is probably easier.
What is their preference for siding?
- Barn steel
- T1-11 Plywood
- Shakes/clapboards (cedar? vinyl?)
- Board-and-batten
There are trade-offs to all of these, too.
What do they want for a roof?
- Barn steel
- Asphalt shingles
Do they want a simple gable roof? With or without overhangs on the ends or eaves? How about a 4-sided hip roof? How steep? With fancy details like dormer windows, turrets, gingerbread and whatnot? (I've seen sheds like this done up like a fancy victorian dollhouse...to hold chickens!)
Do they want it all "new", or can they live with a bunch of reclaimed materials and the structure adjusted to fit?
So the real question here is, are they particular about function and appearance, or is this strictly a bottom-dollar structure?
I bet if you nail down a bunch of these particulars and research a little how each of these techniques are done, you'll be 3/4 of the way to a set of plans. A few questions about how much floor and roof beams you need where and you're the rest of the way there, and you can "crib" a lot of that from the other free ".edu" plans out there on the various cooperative extension websites as mentioned.
Give us a few guidelines of what you need and we can help talk you through this...
/ Shed Plans
Thanks, This is going to be a studio/shed for artistic use on part of the owner so lighting is important. Some of the designs in the links will be useful for this. The owner will finish the interior - we friends will do the structural work.
/ Shed Plans #8
I 2nd glyford's post. Those are all great questions to give us an idea how to save you some money. Answer those and we'll be glad to help you out
/ Shed Plans #9
I, too, am building sheds (12' x 16' in my case) and wonder about this. I was planning to put the 2x8 floor joists directly on prefab blocks. I don't expect I'll ever need to skid the thing around, so I don't need the whole thing sitting on beams.
Also, I'm building on a gentle slope, so I'll need to prop up one side, I was just going to use 4x4 or 4x6 PT between the blocks and the joists.
Will this work?
Last time I built a shed, I used prefab concrete blocks. Those worked beautifully, but I can't find them now. Should I just use flat blocks?
/ Shed Plans #10
Dirk you would be best building on say two skids on the 12' side with 1' overhanging the skids. You should use 4x6's or 6x6's for the skids. That leaves you an adequate 10' span for your 2x8 joists. You would need three or four footings per skid. Preferably four. Sure beats a footing or block for every joist. Make sure to toenail every joist to the skids or use hurricane ties.
Also you can pour footings with post anchors to set your skids on. This will tie the shed to the foundation.
/ Shed Plans #11
So the floor of the shed would be 13" off the grade, right? That's a 6" skid and a 8" joist. And I guess the only way to lower that would be to put footings under each joist.
/ Shed Plans #12
There is a Fine Homebuilding article (subscription may be required) that omits the skids, and simply doubles up the rim joists, which sit directly on patio pavers.
Perhaps that works only because the shed is 8' x 10'? Maybe it wouldn't work for a 12' x 16'.
/ Shed Plans #13
You might still be able to get away with that, if you cut the joists in half (6') and run a double rim down the middle, also on pavers, then use joist hangers on either side (or simply end nail both "half-boxes", then slide them together and attach them after). A whole joist on each end could help tie it all together...?
Also, isn't the roof load carried down to the outside walls? You'd only need to support the middle enough to keep the floor from bouncing.
/ Shed Plans #14
The foundation and for that shed I showed in my previous post looks like this.
I poured a concrete perimeter footing 8" wide x 18" deep (12" below grade, 6" above grade), spread gravel withing the footing and spread 6 mil thick plastic vapor barrier. Embedded J-bolts in the concrete to attach 2x8 sill plates (pressure treated) and installed 2x8 joists on 12" centers with appropriate blocking.
/ Shed Plans #15
The problem with every shed plan that I've looked at is they cut too many corners. Either to save a buck on materials, or because they can use fewer pieces of lumber because there isn't any code. The thing they all have in common is they show you how to build it using the minimul amount of lumber. I've never seen a building built too strong, or anybody going broke over a couple hundred dollars more in lumber. I have seen buildings and sheds falling apart becuase studs were 2ft apart and there didn't use double top plates. The rafters where not sized properly and the sideing didn't have any structual integrity to stop racking. They also use tiny nails and never seem to have any metal bracketry. All cheap things that do not add much to the cost of a small building, but all critical to the long term life of the building. Then they don't use headers with jack studs for the windows and doors, and I've seen corners that where not tied together. But the most common thing that I've seen in those buildings that are falling apart is the lack of a good foundation. Skids are only going to last so long. Concrete blocks sink, and it's never the same all over. Stuff gets under those buildings and builds up, animals make homes in there and they die. Bugs love it under there and the termites will eat through the floor joists before you even know they are there.
If you want a quick and affordable building, it's very hard to beat what you can get one already done at Home Depot or Lowes. You can build it for less in materials, but it's going to take you a week of solid work to get it done, and most of us can make more money going to work then we can save by building it for what you save by doing it yourself. I'm a contractor, and I have a good idea of what it costs to build anything. If a client wants cheap, I'm not the guy for them, and I tell them to buy it already built.
If you want it to last, then you need to take the same steps that go into building a house. Concrete foundation, studs on 16 inch centers, proper headers, two top plates and the proper fastners. Use OSB on the exterior siding, wrap it and then cover with a siding. Deck the roof in OSB, use 30 pound paper, use flashing and nail on your shingles.
Do it right and be proud of it,
Eddie
/ Shed Plans
Eddie
I like your approach, Eddie. We have a contractor and several others with building savvy on this effort. I just needed plans to get us started and to show the person were are building it for so she will know what she is getting and for input for changes. We haven't broken ground yet but we have selected a clerestory design and the project seems to be escalating (on paper) until we know her budget. Thanks to all for the input. Will post pics when available.
Bob
/ Shed Plans #17
I'm not going to build a concrete foundation. It's a shed, not a cathedral.
An even better reason is the tax man. He's got me by the short hairs already, I don't want him getting any ideas.
/ Shed Plans #18
12" block filled with concrete to make it solid makes a pretty decent support for a shed. The problem with using blocks is getting them all set to the same level, but it can be done.
/ Shed Plans #19
Interesting.
/ Shed Plans #20
IMO most free plans you can find on net are too simple and not detail enough. I took the advice from this site and bought a shed plan package. These plans are much better than the free ones.
1999 Sterling Dump Truck (A66285)
1999 Sterling Dump...
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2021 Ford F-150...
2015 GMC Yukon XL Denali SUV (A64557)
2015 GMC Yukon XL...
2023 Schulte FX-318 Flex-wing Rotary Mower (A66285)
2023 Schulte...
New/ Unused Landhonor 2 Stage Air Compressor (A65583)
New/ Unused...
2007 Ford Fusion Sedan (A64557)
2007 Ford Fusion...
