Finally got me a REAL Truck
/ Finally got me a REAL Truck #41
Thats what kinda what I was afraid of. I dont want a little leak turning into a big leak:mad:
Of my current vehichles:
2001 saturn...135000 miles
2008 Nissan Sentra...75000miles
And the truck I traded in, A 2003 silverado w/105000 miles,
NONE of them leaked a drop at all. They were ALL garage kept so I would know.
I'm going to suggest you get that engine steam cleaned, then try to determine where the drips are coming from. Could be something as simple as a few drops from a breather or a poorly installed oil filter.
As you wrote, it is a used vehicle and liked any purchase of a used...well, anything...there is a degree of risk. But don't get paranoid over a few drops of oil...
/ Finally got me a REAL Truck #42
tlbuser said:
No way I'd trade back into a 5.9
Have you ever had any emissions related problems with your 6.7L? I have heard that that soot builds up ahead of the SCR unit and and causes turbo problems.
/ Finally got me a REAL Truck #43
Not true. I have owned more GM cars than any other single brand. GM trucks I do not care for, especially when it comes to HD trucks. I just feel they should be solid front axle.
Chris
I have had both independent and solid axle trucks. The only purpose that "might" make sense is snow plowing. Other than that, I don't see the difference. Ball joints and suspension parts go bad as much,if not more, on the solid axle trucks.
The city of Pittsburgh plows with a fleet of 3/4 and 1/2 ton Chevys, and has been for years. Friends who plow also use independent FE GM's and have no complaints about durability..So that kinda rules the plowing issue out.
/ Finally got me a REAL Truck #44
Just as an aside...
My mechanic put in a splicer u-joint on my F350 that is a grease-able u-joint...
I like it better and I would think that you would too...
You're gonna really like that Cummins...
One tough puller...
I was also going to suggest shopping for Spicer joints... definitely better that "lowest bidder" pieces.
/ Finally got me a REAL Truck #45
I got a few more questions for the general audiuence here:D
First of all, thanks to whoever it was that mentioned the ball joints. I checked them out. With front raised, I can use a prybar and there is about 1/4" vertical movement in BOTH ball joints on BOTH sides. I didnt notice much sideways play IE: pulling out on the top of tire and pushing in on bottom and Vice versa.
Definatally worth having them look at thursday when they are replacing the rear u-joint for me:thumbsup:
And I really hate to sound like a knit-picker here, afterall, it is a used truck, but the 3month/3000mile warrenty makes me want to sure up EVERYTHING, so...I parked the truck in the garage overnight, and there is about 3-4 drops of oil on the floor:confused2: And looking at the underside, the front of the oilpan, sway bar, cross member, and some other parts all have a pretty generous coating of greasy packed oil. You know how it gets on the underside of a motor.
Since this is my first diesel...is this anything to be alarmed about? or is it just the nature of the beast?
I really doubt they will be tearing out the motor to seal up the bottom end on this warrenty, BUT...it is listed as being covered on the warrenty sheet...
I would wash it off at a local self service car wash and see if it comes back. could be a sloppy oil change, could be a leaking front seal... check the oil level and make sure its ok and not overfull..
/ Finally got me a REAL Truck #46
Again, this is not sounding good. It should drip no oil. I have one, a different brand, with 131,000 miles and not a drop.
The GM's are notorious for having a poorly positioned cross member that is a pain when its time for a oil change. There is no way other than a valve like I have in the ones I maintain and a drain hose to prevent coating the frame with oil.:confused::confused2:
Chris
I am sorry, I though we we talking about a 1 ton GM, not a Dodge. Got the threads mixed up.
I have never been under the hood of a Cummins truck so not sure about it. Either way though it should not leak oil. Get it checked asap.
Chris
/ Finally got me a REAL Truck #47
Plowing is a definite disadvantage when using IFS but look at the ratings of the axles. Low front axle ratings were GM's 3/4 and 1 ton downfall along with lighter frames. The frame issue has been fixed on the 2011 and the IFS has a higher rating now but still does not compare to a solid front axle. They even now advertise that they will handle larger plows in the commercials.
Yes, you can run a plow on a IFS. I have. You wear tires out like crazy. It will work but not nearly as good as a solid front axle.
Chris
/ Finally got me a REAL Truck #48
None in 91000 miles C&C with aisin tranny and all original. (no tunes or deletes)
/ Finally got me a REAL Truck #49
... And looking at the underside, the front of the oilpan, sway bar, cross member, and some other parts all have a pretty generous coating of greasy packed oil. You know how it gets on the underside of a motor...
Sounds like it is dripping from the crankcase breather tube/bottle. I'm not sure about 3rd Generation Cummins, but on my 2nd generation (98.5) the crankcase hose ran down the front of the engine and stopped above the axle. When my vacuum pump gave out, there was excess blowby causing oil to leak from the hose. The bottom of my engine looked as you described.
On newer 2nd generation models, the crankcase breather hose is connected to a bottle that leaks oil. The radiator can get clogged up with oil and grime along with the bottom of the engine. I'm not sure how your 3rd generation is set up.
The following links were helpful when I had problems.
Home Page of Mopar1973Man
http://www.cumminsforum.com/forum/
They're knowledgeable folks on there too.
/ Finally got me a REAL Truck #50
Since the title of your post is tantamount to saying that my Toyota is not a "real" truck, I feel justified in offering my opinion about Dodge trucks. :)
It's funny because both of my brothers bought large-sized Dodge trucks and one of them said to me exactly what your title states: " I finally got me a real truck!" After some years have gone by, my truck, with 140K miles on it, stills looks and runs like brand new. Never any problems at all. On the other hand, the oldest brother changed out the rear end in his Ram because it wouldn't handle his huge camping trailer. The other brother, lets just say I've never seen paint peel so badly from a truck only a couple of years old. That is, until he bought the Dodge truck from my oldest brother who said the heck with it. The paint on that second truck started to peel almost the day he brought it home. And I'm not talking about peeling from the hood or roof. On both these trucks the paint peeled from the sides of the truck, in huge chunks. One good thing though, the paint didn't peel right where Dodge spray painted the brand name on the tailgate. You know, when the brand name is spray painted on, ya gotta wonder where else did they cut corners?
After 10 years, guess whose truck is worth more, my Toyota or those big, Dodge Ram trucks?
What if your post title had read "Finally got me a REAL tractor"? How many forum members would take offensive to that? :thumbsup:
/ Finally got me a REAL Truck #51
i like my 98 1500 dodge ram.. but like many dodges of that era.. it has a cracked plastic dash and bad paint. engine is getting weak, and her thirst for fuel hasn't abated any since it has a 360. would be nice if the power door lock on the driver side worked.. :)
she has had 3k oil changes since I got her.. new air filter each time too.
kelly blue book value with paint and dash and 140kmiles is about enough to buy me a beef jerky and store brand cola .. maybee... :)
only redeaming feature she has right now is she is 4wd.. and that seems to be working just fine!!
soundguy
/ Finally got me a REAL Truck #52
First, it is only a real truck if it has 8-lug nuts. Dodge = affirmative.
I agree that a toyota is not a real truck, it is a half ton at best. Resale value and paint quality do not make a truck heavy duty. 6 lugs right?
Great choice in engines to the OP. The 03+ dodges with 5.9 are about as good as it gets.
/ Finally got me a REAL Truck #53
I thought "real" trucks had a minimum of 10 wheels?
Actually, these comments about Toyota or any half-ton (or any other sized pick up) not being "real" trucks is pretty stupid... A truck is to haul stuff and if occasional light hauling is what one needs, then a smaller truck is what one needs...but it's still a truck.
/ Finally got me a REAL Truck #54
Toyota's current model series of 1/2 ton pickups are the most rugged built of any of the 1/2 ton class of trucks. There's much out there to support my opinion. They actually could be rated 3/4 ton in my opinion.
I agree Roy.... all trucks are "real"..... even Kubota RTVs! Just like hammers, you pick the right size to fit the job. 1 ton gas hogs are not for everyone.
/ Finally got me a REAL Truck #55
I believe he was referring to getting a 1 ton vs the half ton he had when he said REAL truck, not one brand vs another.
Your toyota, while more than likely a fine truck, is not a REAL truck. Neither are ford or dodge or GMC half tons. A REAL truck is going to have at least 8 lug nuts although sometimes it must have 10 lug nuts and at least 19.5 tires to be a REAL truck.
REAL trucks also have the springs (and ride) to be able to have a high payload for the bed and also tow large loads. While your toyota might ride nice, there is no way it can handle 2 yards of gravel in the bed or tow a 16k camper.
I agree he got a nice truck with probably the best engine ever offered in a pickup.
Ed
/ Finally got me a REAL Truck #56
That was my point, precisely. I've hauled so many things in my Tacoma I could never count them. I expect it to go another 100k miles easily.
Same with tractors. Large or small, they do what tractors do.
/ Finally got me a REAL Truck #57
Ed
No offense, Ed...but those are a couple of inane comments. Why would you think a truck has to have the capacity to handle 2 yards of gravel? Or 8 lug nuts?
If a truck has the capacity to carry the loads the owner need, then it's a truck. If it doesn't have the capacity, then the owner needs a bigger truck.
But, they're all still trucks...
Boy you guys are getting pretty petty:confused2:
Sorry if I offended any of you.
Maybe I should have worded it "finally got me a bigger truck"
"REAL TRUCK" is a relative term. I guess to a truck-driver, what I have is probabally not considered a "real truck" in his world.
But I do want to thank each and every one of you for jumping in with nothing really important to offer to the questions I asked. Those questions were a lot more important to me than an argument about what a "real" truck is.:confused2:
I guess I will choose my words more carefully next time to appease those of you who have nothing better to do than load a guys thread down with these usless and pointless posts.:mad:
/ Finally got me a REAL Truck #59
Sorry if that offended you. I think there is a distinction between a vehicle with a bed, what I think of as a pickup, and a truck that can do serious work, what I think of as a 1 ton or larger, that is where we are disagreeing.
For example, untill a couple years ago most half tons were built on the same frame as the large SUVs were made on and the only difference was the cab and bed.
I agree the little pickups, rangers and half tons, have there place and are useful to some people but to me they are not REAL trucks. To me, truck means 1 ton or bigger. It appears that to a lot of people truck means to them what pickup means to me, that it has a bed.
Sorry about getting off track LD1.
Ed
/ Finally got me a REAL Truck #60
Not petty at all...you make a post denigrating those of us who have little need for a larger truck...which is probably the majority of we residential owners. A half-ton can carry quite a bit.
As far as your truck...well, never had any desire for a dually...but I would like a full sized pickup. Just don't want the 10-12 MPG that goes with 'em for the few times I could use something bigger. Nor do I want to pay the $20K to $50K a new pickup can cost. That's just me, of course....your money, spend it how you like.
