Did I put the wrong engine oil in? Please help a newbie
   / Did I put the wrong engine oil in? Please help a newbie #1
Ken P
North Granby, CT
Kubota B2410
Folks - I'm changing the oil on my kubota B2410 for the first time, and only after I added half the new oil did I notice that on the front of the oil bottle it says "For Gasoline Engines".
I used Carquest brand (it's a house brand) synthetic, 10w30. Being a newbie and obviously not terribly swift, I'd looked in the manual, saw 10W30 recommended, and just bought the same stuff I use for my car, lawnmower, etc.
Are there different 10w30's for diesel? I've looked in my manual again and see that besides the 10W-30, it mentions "API Service Classification CD, CE or CF" The oil I used, on the bottle says "Meets or Exceeds API SM/SL And all Preceeding API Gasoline categories"
So, what do I do? Should I drain the oil again, and if so, should I also replace the filter (which I also just put on)? How different are those other API grades? I still have to add another 1.2 quarts - should I just get one of the other API grades and add it into the oil that I've already put in?
Many thanks -
Ken
   / Did I put the wrong engine oil in? Please help a newbie #2
You have the wrong oil.
Drain it and change the filter to be safe.
Gas engines use oil rated for a Spark ignition.
Diesel enfines use oil rated for a Compression ignition.
Synthetics are usually rated for both.
I don't think you should have anything to fear once you use the correct oil.
   / Did I put the wrong engine oil in? Please help a newbie #3
I use a marginal diesel-rated oil in Mobil 1 0w30. I just change it once/year, which is usually short of 100 hours and well short of the 200 hours recommended.
If you're going to a synthetic, I'd get one with a broader vis range. 10w30 isn't much for a synthetic. You should be able to find fully diesel rated ones that are 5w40. I wouldn't used anything that has higher than a "5" in that first rating. Otherwise, why use a synthetic?
Ralph
   / Did I put the wrong engine oil in? Please help a newbie #4
Yep you sure want to drain it and change the filter. Sucks but best for the engine. There is a 10W30 diesel rated oil available, but it is hard to find. Really no reason not to use 15W40 which has been the diesel standard for decades.
   / Did I put the wrong engine oil in? Please help a newbie #5
Actually if you don't damage the seal on the filter, why chunk it? Drain it, let it set inverted for a hour or so and reinstall it.Check it while running for a leak as you would always do with a new filter. There is not that much contamination, have you even started the engine? It is not like you poured water into the crankcase?Use diesel certiified motor oil only..
Jonyyuma - No, I haven't started the engine. I didn't even finish filling up the crankcase - it's supposed to take 3.2 quarts, and I had only put in 2 when I had that "Oh, shoot" moment. So you think I could reuse the filter? Or is it not worth trying to save the $10 or so it cost?
I went back to the auto store and got 4 quarts of synthetic 15W-40, Amsoil brand. $10/qt - ouch. They had a nonsynthetic for $4, but at this point I figured I might as well go for the premium stuff.
I'm planning to drain the 10w-30 in the morning, might try to do it cleanly and see if it looks to be worth putting it right back in the bottles.
Thanks for the help, folks.
Ken
   / Did I put the wrong engine oil in? Please help a newbie #7
Ken, I believe most tractors brands advise changing the oil every 100 hours. Using synthetic, it seems like you could go 200 hours.
   / Did I put the wrong engine oil in? Please help a newbie #9
You didn't start the engine so the filter will still be empty. No sense in changing it.
   / Did I put the wrong engine oil in? Please help a newbie #10
Exactly right. There's no reason you can't use the new drained oil in your other equipment either. Other than a time delay and having some extra oil on hand, no harm done.
The diesel rated oil is formulated to have a higher detergent level to better scrub soot from the engine components, among other things.
I use the Kubota 10W30, it's the same price as any other dino oil, and there's no question if it ever comes to a warranty issue.
Sean
EXCAVATOR RIPPER (A58214)
EXCAVATOR RIPPER...
2019 FORD F-150 XLT CREW CAB TRUCK (A59823)
2019 FORD F-150...
FENCE PANELS (A58214)
CATERPILLAR 305CR EXCAVATOR (A60429)
CATERPILLAR 305CR...
Deere 335P (A53317)
Deere 335P (A53317)
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A56438)
2020 John Deere...
