GC Engine Oil Question
/ GC Engine Oil Question #31
OK, I'll admit I'm lazy ... other than coolant losses here & there when I've added, I've never changed my coolant.
/ GC Engine Oil Question #33
So dudes, you convinced me to switch over to 5w40 for this oil change coming up. So educate this here dummy, what's the downside to 5w40 rotella in summertime, none right? And any issue mixing it with 15w40 I have left over, come next oil change in spring/summer?
Also right quick, are you all changing your coolant every year regardless of hrs put on it? I put in the hd extended life stuff last fall.
5w40 will be the same viscosity at operating temperature as 15w40. It is just thinner at startup.
Coolant is typically good for 6 to 10 years. Ten years on virtually all vehicles now. Next year is the 10th on my diesel generator. Time for coolant and all filter and oil change to 0w30 M1 ESP like is in the JD.
/ GC Engine Oil Question #34
So if I mix those 2 together, do I get 10w40?
I figured it would be overkill changing the coolant after a year...it's not as though I'm on the tractor every day.
/ GC Engine Oil Question #35
Ha-ha! Yes, Ray, you're right -- still going on the original battery! (Hey, I may be cheap... but I'm CHEAP!) :)
/ GC Engine Oil Question #36
Probably. Doesn't mix linearly but won't be too far off.
/ GC Engine Oil Question #39
MF wants the coolant changed annually. Yet, they didn't give you a good way to easily do it.
I really don't see any reason to replace it annually either. Perhaps if you put a ton of hours on it?
My tractor is retired. As in, I put less than 10 hours on it this year. It's really hard to get motivated to do a lot of heavy maintenance with that few hours. I am familiar with the arguments for doing it anyway.
Honestly, I probably won't even change the oil this year.
I'm on Battery number 3.
It STILL has the original fuel filter though!!
/ GC Engine Oil Question #40
I just recently changed the 2025R's fuel filter at the specified 400 hours. Going to multiple years on oil. Went 6 years on coolant. Should have gone 10 like on the Isuzu diesel generator.
2023 JOHN DEERE 85G EXCAVATOR (A59823)
2023 JOHN DEERE...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
INSPECTION (A61166)
INSPECTION (A61166)
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
2024 MAC TNAR39FR540 40FT FRAMELESS END DUMP TRAILER (A59906)
2024 MAC...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A59231)
2009 Mariah SC23...
