Loader has scraped up my hood!
   / Loader has scraped up my hood! #1
snpower
Gold Member
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
I should have seen this earlier but the U shaped piece that is used to keep the hydraulic hoses out of the way has been scraping my hood all along whenever I remove or attach the loader. I don't care about the 'Kubota' sticker but there are some non-buffable scrapes on the side of the hood and the 'BX2360' emblem needs to be replaced.:mad:
If I could bent that piece a bit that would do the trick but I'm not sure how; my other thought was to cover it with something along the lines of foam insulation such as is used on pipes. Any thoughts?
   / Loader has scraped up my hood! #2
...Any thoughts?
Any Photos? :D:laughing: Could something be bent on the loader or tractor? It doesn't seem that should happen if everything is correctly set up. :confused:
   / Loader has scraped up my hood! #3
Agreed, maybe another problem....
Here are several shots, which I hope help explain the problem. I placed duct tape on the end of the bracket as a temporary fix this morning.
   / Loader has scraped up my hood! #5
I'd say your hook got bent out a tad. I'd just bend the thing back, to about half the width of opening it now has. Too bad it scuffed up the hood, though...
Thanks for the input I don't agree (that the hood is bent). I see no signs of bending/damage to the hood itself.
   / Loader has scraped up my hood! #7
Your hook is bent inward toward the hood. Bend it out until it is parallel with the loader arm. The opening should be about 2 1/2 to 3 inches. You can slip the hole in the handle of an adjustable wrench over the hook and use the wrench for a lever to bend the hook.
   / Loader has scraped up my hood! #8
The hoses don't look like they need any help to stay out of the way (bundled up pretty good). What would it take to just remove this rod? Got a photo of how it's attached to the tractor and does some else have a photo of how this rod *should* like on a BX 2360?
   / Loader has scraped up my hood! #9
At least the next scratch/ding will be a little easier to digest now :)
   / Loader has scraped up my hood! #10
Ouch!....I agree, that rod needs to be bent back to where it belongs.
2020 Case IH 8250 4WD Combine (A50657)
2020 Case IH 8250...
(INOP) CATERPILLAR TL943 TELESCOPIC FORKLIFT (A50459)
(INOP) CATERPILLAR...
John Deere 2-Row Planter (A50860)
John Deere 2-Row...
Head Rack / Running boards (A50860)
Head Rack /...
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2014 FREIGHTLINER...
18in X 36in Bucket (A48083)
18in X 36in Bucket...
