Loader has scraped up my hood!
   / Loader has scraped up my hood! #1
snpower
Gold Member
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
I should have seen this earlier but the U shaped piece that is used to keep the hydraulic hoses out of the way has been scraping my hood all along whenever I remove or attach the loader. I don't care about the 'Kubota' sticker but there are some non-buffable scrapes on the side of the hood and the 'BX2360' emblem needs to be replaced.:mad:
If I could bent that piece a bit that would do the trick but I'm not sure how; my other thought was to cover it with something along the lines of foam insulation such as is used on pipes. Any thoughts?
   / Loader has scraped up my hood! #2
...Any thoughts?
Any Photos? :D:laughing: Could something be bent on the loader or tractor? It doesn't seem that should happen if everything is correctly set up. :confused:
   / Loader has scraped up my hood! #3
Agreed, maybe another problem....
Here are several shots, which I hope help explain the problem. I placed duct tape on the end of the bracket as a temporary fix this morning.
   / Loader has scraped up my hood! #5
I'd say your hook got bent out a tad. I'd just bend the thing back, to about half the width of opening it now has. Too bad it scuffed up the hood, though...
Thanks for the input I don't agree (that the hood is bent). I see no signs of bending/damage to the hood itself.
   / Loader has scraped up my hood! #7
Your hook is bent inward toward the hood. Bend it out until it is parallel with the loader arm. The opening should be about 2 1/2 to 3 inches. You can slip the hole in the handle of an adjustable wrench over the hook and use the wrench for a lever to bend the hook.
   / Loader has scraped up my hood! #8
The hoses don't look like they need any help to stay out of the way (bundled up pretty good). What would it take to just remove this rod? Got a photo of how it's attached to the tractor and does some else have a photo of how this rod *should* like on a BX 2360?
   / Loader has scraped up my hood! #9
At least the next scratch/ding will be a little easier to digest now :)
   / Loader has scraped up my hood! #10
Ouch!....I agree, that rod needs to be bent back to where it belongs.
New/Unused Quick Attach Pallet Forks (A48837)
New/Unused Quick...
JOHN DEERE 2640 TRACTOR (A50459)
JOHN DEERE 2640...
2021 CATERPILLAR CS34 SMOTH DRUM ROLLER (A50458)
2021 CATERPILLAR...
(APPROX. 65) 33" X 78" EXPANDED METAL (A50459)
(APPROX. 65) 33" X...
2005 Bobcat S185 Skid Steer (A50490)
2005 Bobcat S185...
Three Point Hitch Ripper (A48837)
Three Point Hitch...
