Hauling hay equipment
/ Hauling hay equipment #1
ikold
Member
John Deere 7130
I just purchased a Hesston 1270 swather and 4590 bailer.
Now I need to get them home and I'm not sure if what the best way to do it is. Can I just pull them behind our truck? And if so what kind of hitch do I need to do it with ? The baler seems like it won't be terribly difficult, but the swather is a 14ft cutting width.
Thanks
/ Hauling hay equipment #2
Both of those items are easily towed behind a pickup with no special hitch needed.
What kind of hitch should I use ? There is no standard ball.
So, I take a typical draw bar with a ball on it and remove the ball from it and put a hitch pin through the eye on the baler / moco through the hole where the ball typically goes?
Will need to go get a standard draw bar then. I've got one of those turn over jobbies with three different hitch sizes on it.
BTW what size hitch pin ?
Thanks...
/ Hauling hay equipment #6
Use the largest pin that will fill the holes with the least amount of slop. This will keep the holes from beating them selves out of round. Be sure to put a clip in the hitch pin. If you can get a shock hitch for your truck that would help but not necessary.
Be very carfull and think about what you are doing moving equipment. From the questions you are asking I get the feeling you don't have much expirence with this stuff.
Dan
/ Hauling hay equipment #7
How far will you have to tow your hay equipment? The new tire I had to buy for my JD 336 cost me $175 - after my brother got impatient driving 25mph - and decided to try 40mph!! :mad:
The tire has instructions on the sidewall to limit highway speeds to 25mph, too.
I don't know if I've ever seen anyone "tow" a 14' self-propelled swather, before... 'Course there's a whole lot of things I've never seen before...
That said, I've seen a fair number of swather's just motoring down the road (or actually along the side of the road).
Seen lot's of 'em with the swather on a trailer and the header on another trailer, etc.
Most hitch pins are 3/4" or 7/8" diameter. Varies.
AKfish
/ Hauling hay equipment #8
Thanks
Towed my MF124 baler behind my F150 about 30 miles to get it home after I bought it. Just removed the ball and used a pin (like the one used in the top link of a 3-point hitch).
Kept at 25 mph or less on the back roads.
You'll have to remove the head from that swather and probably make two trips to move that hunk.
Good luck
Just got home. We towed the 4590 bailer with a truck. Simply removing the ball and replacing with a long 1" bolt with 2 nuts on it.
The swather, I drove back with my truck and same hitch pin setup. It was quite an experience with a 14' cut and a 16' 6" transport width we used the WHOLE lane and some of the next lane. Towed beautifully at 50mph the whole way home.
Thanks to everyone for their advice...
How do they move these things large distances ? It must be a colossal pain in the ***.
J
/ Hauling hay equipment #11
A baler would probbaly go on its side, the mower might have the tongue removed and be put sideways on a flatbed.
Aaron Z
living in central IL were JD and CAT build equipment i can honestly say ive seen A LOT Of new farm equipment on semi.... not a single baler has EVER been on its side...
Just saw two mower conditioners the other day on a flat bed... (low boy) towed sideways... (tounge removed)
TRAILER AXLES W/ SPRING SUSP, 10.00-20 TIRES (A64276)
TRAILER AXLES W/...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
Bobcat 435 FastTrack (A60462)
Bobcat 435...
2019 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A61573)
2019 Peterbilt 579...
2019 F150 (A61306)
2019 F150 (A61306)
Skid steer Asphalt attachment (A61567)
Skid steer Asphalt...
