Buying tractor for the first time!
/ Buying tractor for the first time! #1
Western NY
MF 596 FEL
Hi,
I'm closing on a 95.6 acre piece of land within 3-4 weeks. The land is tillable (about 60 acres, and the rest, wooded, previously farmed-now overgrown (about 30 acres), and wet (about 5 acres).
The 60 acre field hasn't been farmed inn about 6 years, and needs bushhogging and maybe more but has no sig rocks and should be tillable without too much work. I may let the next door farmer work this land provided he plants at least some corn (deer!). I want to work on the other 35 that is overgrown (20+ years not farmed). I need to put in a short (200 yd) driveway onto the property, and want to get a tractor and do this myself as much as possible. Also want to put up cover for the tractor and hunting stuff.
I need all kinds of advice on all of this!!:)
For starters, can I get by with a compact tractor with a FEL and pot to put in the gravel driveway? Am thinking about one of those steel pole and fabric structures to protect the tractor this coming winter-- then maybe a pole barn next spring.
I know I'm not supplying enough detais-- but hopefully this is a start!!
Thanks in advance,
Bob
--No tractor YET!!
/ Buying tractor for the first time! #3
Welcome to TBN Bob. You are right that a few more details will help in the advice. Some of the questions to think about are what will the long term usage of the tractor be? Are you going to into hay making? If so will it be round bales or small square bales? All kinds of questions will need to be addressed to help in the decision making.
Yes you may be able to make a road into your place with a CUT and a Box Blade as long as you don't hit rock or stumps and then you may need a track hoe or a back hoe. Sometimes it is better to rent a larger piece of equipment to get the really heavy work done and the size your tractor for the long haul.
I tend to think you will need a tractor in the 35- 45 HP range just to keep up with the maintenance of the property and then if you go into haying it goes up from there.
/ Buying tractor for the first time! #4
With that much land a compact tractor would be a lot of extra work on you and the tractor. I would look mid range 40 to 60 hp. Take time and really review your options so you know what kind of implements you are going to need and run. Best of luck!!
Thanks for the help.
I'm pretty sure I'll turn over the large field (50-60 acres) to the farmer next door provided he'll put in some corn.
So that really leaves my needs as follows:
Put in 200 yd driveway (there is already a driveway there but it's dirt, no gravel, and wet and boggy in spring--so I'm thinking about putting down that fabric I've heard about then gravel, (I may get an engineer to help an it-what do you guys think, considering I'm new to all this). But I would like to do the actual driveway work myself, if the tractor I get will do it.
Also, I want to recover most of the 30 or so acres that was being tilled in the 70's. Maybe this is where I should rent a larger tractor to take out brush/small trees (2-3 inches). Then (please help me here), I would like to plow, disc, and whatever to return it to tilled land). I'll leave some for deer sanctuary. -- seems like a lot of farmers around here put down Lyme --how do you know if your soil needs Lyme?
Lots of questions, so please go easy on the newbie!
Thanks
/ Buying tractor for the first time! #7
Thanks
Welcome Bob,
As far as lime goes, you can have your soil tested, easy to do and a great idea. I would suggest having your local Agriculture agent or DNR guy come out, it is free and they have a wealth of knowledge for your particular area. They can also tell you how to submit a soil sample, or you can find it on your states Ag web page most likely.
As far as Tractors go, I agree with the other guy's, Think long term, that is where most folks loose out and go to small, either way I would strongly consider a 4x4 tractor for a variety of reasons. For me, with that much acreage and it's possibilities, I would also be thinking in the 50 hp + range.
As far as the drive, I don't think you need and engineer IMO. There are enough of us "arm chair " ones on here that are likely to be more help..:D
Western,
Thank you for the helpful info.
If I were to farm with hay and a little sweet corn the 50-60 acres myself, (with the help pf the farming brain trust on this forum), about how much time wouldit take me (estimate in man hours). I have lots of time (retired), and I will get a tractor (big enough after the advice on this forum),
This might include bushog, plow, cutting hay, bailing etc. I have a friendly Amish neighbor, I might be able to share production, with him, and he could supply some of the equipment, and help me with his knowledge. I figure I could also rent some of the accessories for the tractor( I'm not buying a hay bailer!
Am I crazy to try this not ever having farmed before? Would I simply loose my shirt!
This is simply a dream for me (because i spent summers on my grandfathers farm in VA) that would have never been possible when I was working
Thanks again for the help.
Bob
/ Buying tractor for the first time! #9
Bob,
The agricultural economics (or similar) departments at most land-grant universities publish prototype enterprise budgets for various crops. Those budgets will include estimates of labor requirements based upon assumptions regarding cropping system (e.g., no-till versus conventional tillage, irrigated versus non-irrigated, etc.), tractor and implement sizes, etc.
Here's an example of an enterprise budget for sweet corn for SC that shows an estimate of 12+ hours of labor/acre -- http://www.clemson.edu/extension/aes/budgets/files/SweetCorn-LocalIRR.pdf. The SC budget for fescue hay (2 cuttings, small bales) shows an estimate of 7.7 + hours of labor/acre -- http://www.clemson.edu/extension/aes/budgets/files/Fescue.pdf. It is likely that the enterprise budgets for these crops in other states will have different estimated labor requirments due to different assumptions about field operations, machinery sizes, etc. This link provides a convenient way to search for enterprise budgets for alternative crops by state/region -- :: AG RISK EDUCATION LIBRARY ::.
Your best bet is to develop a farm plan to determine the economic feasibility of your proposed operation. This Cornell U. site has some good resources for new farmers that will help you in this regard: New Farmer Hub | Northeast Beginning Farmers.
Good luck.
Steve
/ Buying tractor for the first time! #10
I wouldn't buy anything until you have some experience. I rented 3 different tractors before I bought mine, you can try that. Ask the neighbor who's going to work the land what he thinks you need. If you're going to let him work 60 acres, why not just let him clear the other 30 and work it too?
I'd start small, rent a compact and plant 5 acres the first year. If you like it and want to do more, you'll have some idea of what you need. If you screw up you won't lose much.
It's hard to make money farming, even if you've done it all your life. My family's been farming for 100 years and they told their kids to go into something else. If you want to have fun and relive your youth on the farm, I'd say go for it and have a ball.
/ Buying tractor for the first time! #11
I think it depends on how "busy" you want to be and how much "risk" your willing to take. Raising hay would be the easiest thing I can think of. Fertilize, hope for rain, cut and bale, then store or sell.
If the corn is just for the Deer, then I think doing yourself or with the help of the Amish guy would be no big deal, whatever deal you feel good about. No point making it complicated.
You may just grow enough corn for him and your deer, that may be something he will take the gamble on.
You could also bale the hay "on the halves" You fertilize and someone else uses their equipment to cut, bale and haul/stack it, or any other arrangement that works out.
I agree on renting one too. Go rent a 35hp with a shredder and give it a spin for a day. I had a JD 950 (small, like 28 hp) and a Case 2390 (Big 140hp) and when it came to using a plow, chisel, rotary with a crimper, or even the large rake it was the"big boy" every time. A 50hp would have been just about perfect.
You retired once, time to have a little fun!!
/ Buying tractor for the first time! #12
Hi,
Thanks in advance,
Bob
--No tractor YET!!
What's your budget for the tractor? For implements?
To work 30 acres, I'd be looking for larger CUTs in the 45-65 hp (pto range). As a minimum, something like the Kubota L4400 or my 2008 Mahindra 5525 (54 hp engine, 45 hp pto) would be typical. With the ML250 FEL (6 ft wide bucket, 2950 lb lift to 10.5 ft height), the 5525 cost about $18K (new). I had the dealer weld three chain hooks on the bucket and add the skid steer quick attach option to the FEL. There are triple hydraulic remotes on the rear of the tractor.
DSCF0061 (Small).JPGDSCF0062 (Small).JPGDSCF0067 (Small).JPGDSCF0110 (Small).JPG
200 yards of driveway--remember, the FEL on a tractor is not a digging implement and using it as a bulldozer in hard, undisturbed soil can get you into trouble (bent bucket, FEL arms twisted out of position). Get yourself a single shank ripper (aka subsoiler) to break up the ground and then complete the excavation for your driveway by scooping out the loose soil with the FEL. Here's a typical subsoiler--there are many sources for this implement.
Everything Attachments | Skid Steer Attachments, Tractor Attachments, 3 Point Hitch Attachments, and Farm Tractor Implements.
My driveway is 20 ft wide x 330 ft long, excavated to 6" depth, filled with 3/4" crusher run gravel in three 2" lifts, each lift watered and rolled with a vibratory roller (the big ride-on type). The FEL is a good tool for spreading the gravel.
Good luck.
Flusher,
Thanks for the very helpful info.
In response to your question about my tractor budget, I was thinking about a 50 horse tractor (4wd)with a fel-used would be fine. I was hoping I could get this for about 15k, including a 5-6foot bush hog.
I went to a Kioti dealer today, and he tried to sell me a Kioti with a fel, new, for 29k +8% (NY sales tax!). And the brush hog would be another 2.5-3k. More than twice my budget!
This dealer said there aren't any mid-sized utility tractors on the used market, but I seem to see a lot with Internet searches.
Seems like there are used tractors with low hours -- are these apt to be lemons?
Thanks in advance.
Bob
/ Buying tractor for the first time! #14
You might give the most thought to harvesting and where to market your crop.....Tony
/ Buying tractor for the first time! #15
Gee, the DEALER said there are no used machines on the market and you HAVE to buy new (from him). :confused2: :confused2:
Riiiiiiight.
Used tractors are often NOT lemons. Getting one and having it delivered isn't that expensive or hard. Just do your home work and avoid the ones being sold by a former king.
Ford Tractor,
I got it.
I haven't bought a new car since 1985--I buy one year old cars with 10k miles, and 3 years left on the warranty for 25-30% less than the new price.
I plan to buy a used tractor for the same reasons, but with no warranty, how can I protect my 15-20k purchase-- can I have my own independent tractor mechanic go over it before the purchase? If not that, what else.
Thanks,
Bob
/ Buying tractor for the first time! #17
Bob,
Sure you can have your mechanic go over it! Get a mechanic lined up ahead of time ,so when you do find something your serious about , he can make the "house call".
I have bought a couple of "used" tractors with little problems, one from a dealer which ended up being a great deal since it was a trade in and a different brand than they sale.
You might keep an eye on Craigslist in the "farm and Ranch" section, also look on "equipment trader. com" and any where else you can find in your area. Only tractors I would avoid is "Grey market" ones, Just my opinion.
Western,
Thanks,
there's a huge "farm equipment fair" in august about an hour from my house and I think I'll go there-- apparently every dealer in western ny will be there with new and used equipment.
I figure I'll rent a tractor to brushhog my field next month if I don't buy one by then-- as some of the guys have suggested-- renting does sound like a good way to try out different tractors.
I'm getting great help from our farmers co-op extension that is run by cornell- i went to their office today and they were very helpful.
I really appreciate all the help from you guys.
/ Buying tractor for the first time! #19
Western,
Thanks,
You might as well wait and go to the
annual used equipment auction
to see what the proces are bringing
the day after the farm days on the
same Ronald Lott farm.
They never exibit used equipment on the
grounds during the EFD show.
Thanks Leonz,
I might go two days just to see the new stuff then the auction.
Much appreciated.
Bob
2013 WACKER NEUSON  LTN8 LIGHT PLANT (A67714)
2013 WACKER NEUSON...
THE MACHINE CO. THAWZALL H250 HEATER (INOPERABLE) (A68842)
THE MACHINE CO...
2014 MAC FLAMELESS HEATER (INOPERABLE) (A68842)
2014 MAC FLAMELESS...
CAT D9H 4BBL Multishank Ripper (A68134)
CAT D9H 4BBL...
2007 FRAC TANK 500BBL WHEELED (A68842)
2007 FRAC TANK...
2006 Isuzu (A64911)
2006 Isuzu (A64911)
