Oil & Fuel Gallons per hour
/ Gallons per hour #2
What would be the gph of a DK65, light work?
For a well tuned diesel engine of a wide range of HP the following is pretty accurate.
A good rule of thumb to get you in the ball park is 0.07 to 0.08 gallon per hour per HP produced.
That is with the machine operating in the 25% - 100% HP range. Some will do a little better and some a little worse.
/ Gallons per hour #4
If my calculations are correct, then my DK45 would use about 3 gallons per hour. Though I haven't really checked it, I can say I get much better gph than that. I've always thought mine was in the 1-1.5 gallons per hour range. Maybe I should check it closer.
/ Gallons per hour #5
Three gallons per hour for a DK65 seems very high even if you are running at PTO speed under load. My DK40se gets something close to a gallon and hour working hard.
/ Gallons per hour #6
I am pretty sure my usage is just a tad over 1 gallon per hour when brush hogging. Formula says it should be closer to 3 for gross hp and 2.5 for PTO hp.
Formula may not be well suited to these modern compact tractors.
/ Gallons per hour #7
His rule was gph/hp **produced**. Most people don't load their tractors to anywhere near full capacity.
50% of rated capacity sounds like a good number for most operations, and that would make the calculation consistent with use.
Just running at full speed with no external load consumes ~5 hp, and its associated fuel, on my tractor, and my usage doesn't increase much no matter what I do(I don't do tilling).
Chris
/ Gallons per hour #8
The amount used depends on the HP required. Most people only use maximum HP in short spurts. I have a 44HP Kubota and I get between
0.75GPH(best) - 1.5GPH(worst). If I loaded it as full as I could get it and held it steady at that load I would use about 3GPH. I ran into this rule of thumb while sizing large generators some over 1 megawatt. The rule still applies. Just gets you in the ball park. I tested my little 6.5 KW diesel generator with a known load so I knew the KWs and it fell in the 0.075GPH per KW.
1 HP = 746 watts
/ Gallons per hour #9
Chris
I thought his calculations were in the 25% - 100% range. I would think I'm in the 25%+ range for most of my work. If not, I bought too big of a tractor. :)
/ Gallons per hour #10
The rule of thumb calculations are more accurate in the range of 25%- 100%.
I thought this was useful for planning. Remember it is a ballpark number.:D
/ Gallons per hour #11
my DK45HST with 100 hours on it used 6.1 gal of diesel for 2 hours work at 2,500 rpm pushing a plow.
this is the only time ive actually checked it and verified it.
/ Gallons per hour #13
Hi,
Might want to check
TractorData.com - Farm tractors
If they have yours listed with test results.
(it will tell you the results of the neb.test for fuel use.)
I've taken a pass on what seemed to be a good deal on a few tractors due to the fuel consumption. When it takes 4-6 gal. per hour to run them,it puts the cost to high for me to justify having them.
Guess that I'll hang with my old JD (less than 2 GPH.)
-J.C.-
/ Gallons per hour #14
johnecash said:
Hi,
Might want to check
-J.C.-
I would be careful accepting estimates like 4-6 gph operating a tractor less than 60-100hp. Virtually all diesel engines consume the same amount of fuel per horsepower of work. The variation may be 10% but not 200-400%. Almost every modern diesel will be at least as efficient as an older engine too.
/ Gallons per hour #15
These charts from an old thread may be useful.
Here is the link:
http://www.tractorbynet.com/forums/2521649-post29.html
If I read the charts right, the DK45 operating at normal PTO speed should use about 2.5 gallons per hour, which is in the neighborhood of what I estimate is my fuel consumption rate. I think there'd have to be a leak somewhere to use 6 gph with a DK45.
BOB
/ Gallons per hour #16
I didn't explain that well. ---
Should of said that when looking at a larger tractor, the difference in fuel consumption keeps me happy with the 48hp that I have now.
-J.C.-
2025 Auger Drill Bit Skid Steer Attachment (A64553)
2025 Auger Drill...
UNUSED JCT 2 PRONG BALE SPEAR (A65055)
UNUSED JCT 2 PRONG...
2016 Ford F-250 Auto Crane 3203 3,200lb. Crane Service Truck (A64556)
2016 Ford F-250...
1528 (A65054)
1528 (A65054)
NEW HOLLAND 853 ROUND BALER (A64278)
NEW HOLLAND 853...
2002 Chevrolet Express 3500 Shuttle Bus (A64194)
2002 Chevrolet...
