Oil & Fuel Gallons per hour
/ Gallons per hour #2
What would be the gph of a DK65, light work?
For a well tuned diesel engine of a wide range of HP the following is pretty accurate.
A good rule of thumb to get you in the ball park is 0.07 to 0.08 gallon per hour per HP produced.
That is with the machine operating in the 25% - 100% HP range. Some will do a little better and some a little worse.
/ Gallons per hour #4
If my calculations are correct, then my DK45 would use about 3 gallons per hour. Though I haven't really checked it, I can say I get much better gph than that. I've always thought mine was in the 1-1.5 gallons per hour range. Maybe I should check it closer.
/ Gallons per hour #5
Three gallons per hour for a DK65 seems very high even if you are running at PTO speed under load. My DK40se gets something close to a gallon and hour working hard.
/ Gallons per hour #6
I am pretty sure my usage is just a tad over 1 gallon per hour when brush hogging. Formula says it should be closer to 3 for gross hp and 2.5 for PTO hp.
Formula may not be well suited to these modern compact tractors.
/ Gallons per hour #7
His rule was gph/hp **produced**. Most people don't load their tractors to anywhere near full capacity.
50% of rated capacity sounds like a good number for most operations, and that would make the calculation consistent with use.
Just running at full speed with no external load consumes ~5 hp, and its associated fuel, on my tractor, and my usage doesn't increase much no matter what I do(I don't do tilling).
Chris
/ Gallons per hour #8
The amount used depends on the HP required. Most people only use maximum HP in short spurts. I have a 44HP Kubota and I get between
0.75GPH(best) - 1.5GPH(worst). If I loaded it as full as I could get it and held it steady at that load I would use about 3GPH. I ran into this rule of thumb while sizing large generators some over 1 megawatt. The rule still applies. Just gets you in the ball park. I tested my little 6.5 KW diesel generator with a known load so I knew the KWs and it fell in the 0.075GPH per KW.
1 HP = 746 watts
/ Gallons per hour #9
Chris
I thought his calculations were in the 25% - 100% range. I would think I'm in the 25%+ range for most of my work. If not, I bought too big of a tractor. :)
/ Gallons per hour #10
The rule of thumb calculations are more accurate in the range of 25%- 100%.
I thought this was useful for planning. Remember it is a ballpark number.:D
/ Gallons per hour #11
my DK45HST with 100 hours on it used 6.1 gal of diesel for 2 hours work at 2,500 rpm pushing a plow.
this is the only time ive actually checked it and verified it.
/ Gallons per hour #13
Hi,
Might want to check
TractorData.com - Farm tractors
If they have yours listed with test results.
(it will tell you the results of the neb.test for fuel use.)
I've taken a pass on what seemed to be a good deal on a few tractors due to the fuel consumption. When it takes 4-6 gal. per hour to run them,it puts the cost to high for me to justify having them.
Guess that I'll hang with my old JD (less than 2 GPH.)
-J.C.-
/ Gallons per hour #14
johnecash said:
Hi,
Might want to check
-J.C.-
I would be careful accepting estimates like 4-6 gph operating a tractor less than 60-100hp. Virtually all diesel engines consume the same amount of fuel per horsepower of work. The variation may be 10% but not 200-400%. Almost every modern diesel will be at least as efficient as an older engine too.
/ Gallons per hour #15
These charts from an old thread may be useful.
Here is the link:
http://www.tractorbynet.com/forums/2521649-post29.html
If I read the charts right, the DK45 operating at normal PTO speed should use about 2.5 gallons per hour, which is in the neighborhood of what I estimate is my fuel consumption rate. I think there'd have to be a leak somewhere to use 6 gph with a DK45.
BOB
/ Gallons per hour #16
I didn't explain that well. ---
Should of said that when looking at a larger tractor, the difference in fuel consumption keeps me happy with the 48hp that I have now.
-J.C.-
2021 POLARIS RANGER XP1000 RTV (A65054)
2021 POLARIS...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A64194)
2013 Chevrolet...
Woodsman 332 T/A Towable Brush Chipper (A64194)
Woodsman 332 T/A...
2007 VOLVO VHD QUAD/A VACUUM TRUCK (A67148)
2007 VOLVO VHD...
2015 Chevrolet Equinox SUV (A64557)
2015 Chevrolet...
