Frontier BB2048L work on 2320?
/ Frontier BB2048L work on 2320? #1
JeffinNE
just outside Lincoln, NE
JD 2320 & JD LT190 mower
Found a good deal on a used Frontier BB2048L box blade for my yet to be delivered JD 2320. Found a website with specs and it says Cat 0 or limited Cat 1 compatible for hitch. The 2320 is full Cat 1.
Will the BB2048L hook up to the 2320 as is or will changes need to be made?
/ Frontier BB2048L work on 2320? #2
It may fit. Depends on the lift pin size as this unit is available with Cat 0 or 1 pin options. However it is a lightweight unit at only 275 lbs. I suggest you keep shopping for a BB2048 (not L) which is cat 1, heavier at 385 lbs and overall better suited for a 2320.
Weight is a plus for box blades, plus this unit has only 3 scarifiers versus 4 for most 4 ft box blades. But I do see the United 448HD on Everything Attachments weighs only 318 lbs while the BB2048L is 275 lbs. The United unit looks real nice.
For the price I can get for this unit, may be too hard to pass up.
/ Frontier BB2048L work on 2320? #4
I ordered a BB2048, and my dealer accidently got the 2048L. I tried it out, but thought it was pretty light-weight on my 2320. When I finally recieved the non 'L' version I couldn't believe how much heavier built it was, worked a lot better -- especially with the 4 shanks. The 2048L will get the job done, but the BB2048 is quite a bit heavier, taller and better built.
/ Frontier BB2048L work on 2320? #5
I opted for the BB2048 for my smaller JD2305 to do double duty as a counter weight to the FEL. I liked the additional weight as mentioned by other posters.
/ Frontier BB2048L work on 2320? #6
I looked at the 2048L and a Cammond 48" boxblade which the dealer sells. Went with the heavier Cammond as the dealer didn't have a regular 2048 and this was for my lawnmower. Works OK have only used it for a few hours so far without problems.
For your 2320 and up I recommend getting the heavier boxblade for sure.
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
2019 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 KENWORTH T680...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
2008 Kaufman Wedge Trailer (A62613)
2008 Kaufman Wedge...
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A63689)
2012 Ford F-150...
2006 Western Star 4900 Concrete Mixer U98352 (A62613)
2006 Western Star...
