Battery issue
/ Battery issue #1
CT230 Fan
Stewartsville, MO
Bobcat CT230
Well, everything had been going great with my CT230, until I tried to start her up on Saturday. When I turned the key, the tractor made some strange noises and the lights on the dash were dim and flickering. So, I figured the battery must have been run down, so I went to put the charger on it, and popped open the protective cap on the positive terminal and saw that it was completely full of corrosion. I went ahead and hooked up the charger and let it complete the cycle. Same problem when i tried to start it again, so I proceeded to loosen the clamp and it just fell apart on me.
I have a replacement on order, but I can't imagine why the battery would have that much corrosion.
/ Battery issue #2
I only have 35 hours on my CT235 and after reading several threads on the leaking battery acid decided that I didn't want any part of it and replaced it with a Sears Diehard Platinum P-1 - Maintenance free battery. I started to notice corrosion with the original bobcat battery within 10 hours. Since I replaced the battery tray looks like new, no corrosion and so glad I made the change. I would just go ahead and go with a maintenance free battery so you don't have to go through that again. It will put you back about $200, but you shouldn't have that issue come up again.
/ Battery issue #3
Looks like the battery is being overcharged, and the off gasses are getting trapped in the protective cap.
/ Battery issue #4
Yes, I would check the charging voltage, it should be between 14.00 to 14. 3 normally. 14.5 to 14.7 will cause gassing and 14.7+ is an overcharge condition.
/ Battery issue
Not to sound completely ignorant, but how do you check the charging voltage? Check it while the tractor is running? I have never had to manually charge the battery.
/ Battery issue #6
Use a voltmeter at the positive & negative posts with engine running about 1/2 throttle, then at full throttle to make sure regualtor is working correctly.
/ Battery issue
I will check that out as soon I can get the new battery cable in and installed. They said it should be in Wednesday. I hope so, my grass is getting pretty tall.
/ Battery issue #8
Yeap. My battery leaked all over the engine compartment and made a huge mess. I went with the Sears Diehard Sealed maintenace free battery
after cleaning up the mess and painting.
A sealed battery is peace of mind.
/ Battery issue #9
Thanks for the posting. My CT 230 is 7 months old and has 54 hours on it. I checked the terminals and the positive was corroded. I scraped it and soaked it in baking soda, greased it and put it back on. I don't really want to buy a new battery so soon. I will keep an eye on it and even if your tractor is new I would check this out. I was surprised by the ammount of corrosion that was there.
/ Battery issue #10
I guess I was lucky with this problem. My battery died suddenly about 8months ago. It hadn't leaked or anything ... just died. The dealer replaced with a new battery and all has been well. No leaks or issues.
MoKelly
/ Battery issue #11
At 35 hours my battery shows no signs of leakage at all. I am never on anything other than flat ground except when cutting my 180' of frontage culvert. I wonder if my Canadian marketed tractor has a different oem battery manufacturer.
/ Battery issue #12
Don't the dealers choose and install the batteries, meaning that each locale may install a different quality of battery? I'm on year 6, original battery, 460 hours or so, no leaks, starts right up even after long spells of sitting unstarted. I do use a battery tender in the winter because my tractor sees very littel use then.
/ Battery issue #13
Is there a brand name on your battery? Today's have Bobcat insignias on them although I doubt Bobcat actually makes batteries. Same as Kubota brand hydro oil in Canada is made by Petro-Can and is a semi sythetic blend of Duran. In the US, Kubota hydro, both UDT and SUDT is made by Valvoline. One is dino and the other s synthetic blend. Canada doesn't have a dino due to the temp. I did notice some moisture on the cap on one side, today.
/ Battery issue #14
I should point out that I have a Kioti. BC may dictate specific batteries for theirs. But, I think Kioti lets the dealers pick the battery. I'll try to see if there are any markings on my battery. I'm sure there are, as I think there has to be in order to meet DoC safety requirements.
/ Battery issue #15
I have a leaking battery too since 100hrs. ago... I was told by my dealer when I mentioned it a while back that it is not included on warranty by Bobcat. I was surprised but nothing you can do. So I just hose it off and pray that it last another day. I just did my 350 hrs. last weekend and so far battery is still good. Although I think I'm on borrowed time since 100hrs ago. When it stop working I will just get another brand of battery.
2022 Sany SY215C Hydraulic Hammer (A62679)
2022 Sany SY215C...
(APPROX. 30) WOOD VEGETABLE BINS (A64276)
(APPROX. 30) WOOD...
Landhonor No Till Seed Drill (A62679)
Landhonor No Till...
Sterling AT (A63689)
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
Adams Tilt Trailer (A63688)
Adams Tilt Trailer...
