Recommendations please
/ Recommendations please #1
hyperrust
SC
Kioti DK40, Bobcat CT2025
Hi, I'm a relatively new member. I posted once when I was considering buying a new Kubota L3700SU. It turns out I wasn't quite ready to buy then. I'm getting closer now, and the more I learn about tractors, the less I know which one I should buy.
My wife and I bought a 22 acre horse farm in Alabama. About 2 acres are wooded, 2-3 are driveway, lawn, etc., and the rest is grass (read: weeds) pasture. It's gently sloping/hilly, and close to one of our mini "mountains" we have here, which makes for a fair amount of softball sized rocks in some parts.
We've been getting by with a ZTR mower, old lawn tractor with a cart, and a new ATV with a bigger cart. We're getting close to the point of needing a real tractor now that we have 5 horses to take care of. Our chore list will be:
  • -brush-hogging (possibly finish mowing one day) 10-15 acres of pasture. Right now half of this is grazed by horses, and the other half is unfenced and growing unchecked. eventually a large majority will be fenced and grazed
  • -compost pile flipping/moving with FEL
  • -moving sand/soil/gravel piles
  • -moving brush/down trees (grapple?)
  • -pasture care (spreading fertilizer, chain harrow, etc)
  • -digging post holes (ideally with a downforce cylinder with our hard clay earth)]
  • -gravel driveway maintenance / box blade work
  • -ideally, moving round bales from ground to ground location (no high overhead lifting)
  • -arena dragging
  • -no plowing, heavy ground engagement work, etc.
  • -other stuff??
New or used is OK. I'd prefer HST so my wife is comfortable using it, but gear with shuttle shift is not completely ruled out. I'm thinking 35-45hp range. Would prefer 4wd, but I suppose if it's closer to utility size and heavy then 2wd might be OK... but I'll be using the loader a fair bit, especially for the compost pile.
Kubota/New Holland dealer and JD are close and I like them both. A Mahindra dealer is 45 minutes away. Kioti is 1.5 hours or so, and I like the prices, but I don't know much about the tractors.
Looking for any and all suggestions. Any particular used units that might be good? Is utility size too big for what I need? I've never had a tractor before-- raised a "city" boy in a town of all farmers.
Oh, and someone I work with is trying to talk me into buying a skid steer instead of a tractor. It sounds appealing except for the cost of those front mount brush hogs... any pros/cons on this?
/ Recommendations please #3
It sounds like you pretty well have the size dialed in and my choice would be in the upper end of your power range. I can't speak to hay as we always used a bigger tractor for that; sure the real farmers on here can provide good advice.
I see no need for anything bigger than a CUT; UT will work, we have an M8540, but you are talking a lot more money and operating costs.
As to the skid steer, they are really handy for some things, but after using one a while we much prefer tractors for their overall versatility. I am sure others will disagree.
As to 2WD/4WD, we have both and I will never buy another 2WD unless it is for our flat land farm and no FEL; again others will disagree.
Good luck.
/ Recommendations please #4
Kubota L 5740 Grand would be my recommendation. You would have plenty of power, lift capacity loader and 3 point. Skid loader quick coupler on fel for attachments. Plus a/c, radio, for mowing in those hot summer days. They have the new HST Plus which is REALLY nice. Don't have to worry about throttle and stall for loader work etc. Check into it. It will be the last tractor you buy.
/ Recommendations please #5
Same as Triple R Sounds like you need a CUT about the size of my L3400HST The new model is the L3800HST. Yes I agree with you the Hydrostat will be the best for you as loader work is high on your list, and not just your wife will enjoy the ease of use, the precision and safety of the Hydro. You too will really come to appreciate it. I would pick the dealer I trusted, then pick a tractor in the 35 horse range give or take a few. As for Kubota/New Holland, Deere, you cant go wrong with any of the three. Oh and 4wd without question, Tractors are all about "traction" and be sure to get the SSQA (skid steer quick attach) on the front end loader, I didnt buy it originally but added it later, cost less up front. Good luck, and report back in when you do buy, with pictures:thumbsup:
James K0UA
/ Recommendations please #7
id say step up to an MX4700 or MX5100 HST 4x4 with LA844 quick tach fel.then youll have the hp for shredding moving an claning up down trees digging postholes an moving big round bales.
/ Recommendations please #8
I would say that whatever is large enough to handle the round bales is the size you need. You need a bit of weight to go up and down hills with that much weight on a hay spear. You are getting a front end loader, so that will add about 700-900 lbs to the outfit. I would think any tractor over 3000lb( some compact tractors are lighter than you expect) and with at least 35hp would do the job. I think most of the other jobs could be done by a smaller tractor if you had to. Don't spend all of your money on the tractor and not leave a little for attachments. If it has a gearbox, consider new otherwise used is fine and 20-50% of the price of new.
/ Recommendations please #9
After you stop at the JD and Kabota dealerships, take time to check out that Mahindra dealer, too. You can't go wrong with any of your choices....but the 5035 HST should at least be looked at. If you do a lot of mowing, you might consider a cab'd tractor though.... good thing to have if you are working out in the dust. The big 35.5" 14 X 17.5 front tires make everything look out of proportion....but here is a picture of mine. Good luck looking....that is half the fun. [ the buying and paying for is the hard part ]
Loving the recommendations so far, thanks!
I hadn't considered the MX4700, but it sure is sounding appealing now... sounds like a bit more than I need, but would likely end up being just right.
I assume I could run a 7 foot rotary cutter with the MX4100?
/ Recommendations please #12
JerryK,
That Mahindra 5035 is sure a nice looking tractor I must say.
DevilDog
JerryK,
DevilDog
Agreed, that thing is BEEFY! Love the backhoe, probably won't be springing for one of those initially though. :(
/ Recommendations please #14
Even thought the Kioti is further away, take a ride and look at the DK45SE HST with CAB or DK50SE HST with CAB. I just got the DK50 and love it. That CAB makes being out in the 98 deg weather easy! Especially if you are going to be doing a lot of cutting. I would also assess if you need to put a 4n1 or grapple on it to help with any clearing.
/ Recommendations please #15
Like others have said you've dialed in your needs pretty much. You really can't go wrong with any of the major players. I'm partial to Deere but wouldn't hesitate to go with Kubota or Massey or Mahindra. In my case the Deere dealership was the closest. With 22ac IMO look for something around 40 - 50 HP. With that you can step up to an 8ft rotary cutter with ease and that will make cutting that weed patch a breeze and you'll still have time at the end of the day to go riding:) Weight is your friend (or foe) depending on what you're doing. Because you already have a ZTR for your lawn I'd forgo the finish mower for the fields.
Good luck.
/ Recommendations please #16
Good luck.
Agreed, you can't buy a bad tractor new from any of the top five or so and even a different color may be the same tractor. My preference is Kubota, but I like them all with dealership playing a very important roll in what we own. We do have red and green tractors as well as orange.
/ Recommendations please #17
If you are looking for bang for your buck check out the Kioti DK40se or DS4110 open station along with equivalent Mahindra tractors. You will need more loader lift and tractor weight than the Kubota B3700 to safely handle full round bales and except for the L4400 I think you'd pay about $10K more for the Kubota or JD equivalents of the Kioti and Mahindra.
/ Recommendations please #18
I was in a similar situation as you, just a few less acres. I'd look for a good used tractor in the 35 HP range (no less). I only know kubotas. they make good stuff and with care are a good investment.
You will find uses for 4WD, it basically allows you to use more of the HP you have.
Be patient, scour all sources for used tractors, get your financing ready to buy quick if needed. and, you may get good pricing on some implements with a used tractor. box blades are typical. my used kubota had a dented hood which knocked several hundred off the price. the dealer had a scratched one that a customer refused on a new tractor - got it cheap and now she looks great. it will fall into place, just leave yourself some latitude on the models you will accept. and have fun with it - that's why you bought the farm in the fist place.
The Kioti dealer offered a DK35SE HST with KL351 loader and Rhino 160 cutter for $21,300. He advised against HST as it's an $1800 option on the Kioti. Says he's only sold a couple HST models of that tractor in the past two years.
He also offered the DK35SE gear/shuttle with loader, same cutter, Union box blade, and a grapple for $21,400 + 3% tax = $22,042.00 The loader is "free."
How much more am I looking at for a MX4700 with loader, cutter, and HST?
/ Recommendations please #20
The loader for the DK35se lifts a bit more than 1500lbs. I'd suggest you need more to easily handle full rounds. The loader on the DK40se and DS4110 lifts 2700+lbs so would be a better choice. Not a huge difference in price either.
I have the DK40se HST and love it. If you do a lot of loader and grapple work it is really nice. For mowing and field work not such an advantage. By the way I also care for about 25 acres half of which needs clearing.
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
THUNDER CREEK 460 GALLON FUEL TRAILER (A60736)
THUNDER CREEK 460...
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
PORTA COOL 2000 PORTABLE EVAPORATIVE COOLER (A59823)
PORTA COOL 2000...
SD Lanch 20'x30' All Steel Carport (A60462)
SD Lanch 20'x30'...
