Can PT-425 handle Sabre Saw?
/ Can PT-425 handle Sabre Saw? #1
Clumber
Gold Member
Northern Virginia
Kubota B2601 HST Nov 2019
Folks, I am considering using the Sabre Samurai Saw to trim trees, and along ponds and ditches:
http://www.cutthat.com/features.html
I think this will work in the manner described below. However, I am still concerned about the max operating pressure of 500psi. Will restricting the throttle also keep the PSI within range? I think that using the PTO rather than the Aux is the way to go. Any suggestions are appreciated.
You are correct you could control the speed the cutter operates by varying the rpm of your tractor. You just need to make sure the cutter knives can be seen with the naked eye, if they are going faster and are a blur to the eye than you are outside the operating range.
The operating flow rate of the cutter is 3.3 gpm with a maximum operating pressure of 500psi.
Regards,
Grant Gaudes
Canadian Agri Technologies Inc.
1 866 792-8437 begin_of_the_skype_highlighting**************1 866 792-8437******end_of_the_skype_highlighting
www.cutthat.com
Sabre Crop Dividers
I am interested in the Sabre product. I need to determine if I need to install a flow regulator to operate the saw on my tractor. My tractor is the Power Trac 425 Utility tractor (Versatile Tractors,Compact Tractors,Trailer Packages,Landscaping,Utility Vehicle Rentals,Mowers-Power Trac.
I have two possible hyd take-offs.
1. PTO- 8 GPM @ 2500 PSI, 1/2" hoses.
2. Aux- 4 GPM @ ????, 1/4" hoses.
I think that using the PTO to drive the sabre while keeping the throttle at less that 1/2, and manage the cutter speed by eyeballing the cutters, I can control the GPM without a flow regulator. What do you think?
Also, I'm confused -- your home page spec says: 3.3 GPM at less than 500 psi during normal operation, while the manual says the motor Hydraulic Pump requirements - minimum flow of 10
GPM @ 500 psi????
/ Can PT-425 handle Sabre Saw? #2
Regards,
Grant Gaudes
www.cutthat.com
Sabre Crop Dividers
GPM @ 500 psi????
I wouldn't even consider using it without some sort of pressure regulator.
/ Can PT-425 handle Sabre Saw? #3
I have one for mine and have used it quite a bit. I fabricated a couple different attachments for it so I can use it as an out front cutter. It works great on all my briers around here. I tinkered with the original clamp so it will tilt in the directions I want it to. You have to get a diverter. I found mine on ebay for about $55 so you can reduce the flow and still have wheel speed and torque.
Thanks Gravy and Coolconnection for responding. I see that it is going to be more complicated but doable. Coolconnection, do you employ a pressure regulator as Gravy suggest? Can you please post a photo or video of your fabrications? Do you run the saw off the Aux or PTO circuits? Also, as I am new to hydraulics. I don't understand the need for a diverter to maintain wheel speed & torque -- e.g., I can run a demanding brush cutter without the need for a diverter? Sorry if these are dumb questions.
/ Can PT-425 handle Sabre Saw? #5
Nope, no pressure regulator. The diverter really cuts down the pressure, it would probably be wise to have one but I don't and it works fine for me. If it catches on something big I just shut the PTO off. I use the PTO with the diverter. Well if you slow the engine down so the cutter works at the proper speed you really don't have much hydraulic pressure to turn the wheels. I have hills and slopes so torque is needed for what I use it for. If your lot is relatively flat it may not be a problem. Like my college professors always said, "no such thing as a dumb question". I will have to post pics in a few weeks, no time right now.
Thanks, looking forward to those pics. Is a diverter a flow regulator? Am also wondering if the saw can be run off the Aux which already has a low flow of < 4 GPM -- maybe would not need a diverter...
/ Can PT-425 handle Sabre Saw? #7
Clumber: I would strongly suggest that you use what is called a pressure compensated flow control valve to run this piece of equipment. This is a very accurate device to control the speed of a piece of equipment regardless of engine speed. You can find them at any hydraulic supply company in the yellow pages or at the Surplus place in the midwest that everyone refers to on here. Brand Hydraulics makes a good one. You need a small one with a 10 GPM capacity. It will have three ports: The "P" port receives oil from the pressure line on your 425 PTO circuit. The CF or controlled flow will conect via hose TO your cutter tool, and the "EF" port on the valve (excess flow) will go back into a "T" fitting in which you will also install the return line hose from your tool. As the engine speeds up the excess flow from the fixed displacement pump is simply dumped back into the tank. The controled flw is set using a small lever on the vlave at whatever speed you want the cutter to operate.
Also: If the motor on your cutter tool does not have a bypass pressure relief valve built in, then install one with three ports, pre set to the max operating pressure of cutter. This will connect via a pipe nipple with the inlet port of the flow control and the pressure line from the PT. The pressure relief valve oil will dump oil back into the PT return line via another "t" in the hose returning oil to the quick disconect return line in the event your blade ever jams, you cannot react as fast as the valve can! You will basically make up a "kit" with quick disconnect fittings to match the PTO fittings on your 425. It can all be made very compact using the right fittings from your hydraulic supplier mounted on a small steel or aluminum panel with the valves on it which can bolt onto the quick attach plate adapter you will inevitably need to mount this cutter. You can purchase a couple of PT's quick disconect fittings and have your local supplier make up half inch ID jumper hoses to connect from your new valves to the PT. You will start and stop the cutter with your current toggle switch on the dash. If you draw this out on note paper it is quite a simple circuit and will work like a champ.:thumbsup:
/ Can PT-425 handle Sabre Saw? #8
The info you have about pressure is wrong or misleading. The hyd motor drive has no problem at 2500psi. Call the manufacturer.
larry
larry
Are you referring to the info on the Sabre Samurai Saw. The manufacturer says the saw operates at 3.3 GPM at max 500 PSI.
/ Can PT-425 handle Sabre Saw? #10
FAZTRAC is correct and that is what I have. I should have said that but I had diverter stuck on the brain. It controls the hydraulic flow to the tool and diverts the rest to EF back to the pump. Got all the hoses and fittings from TSC except for the hydraulic connectors. Prince makes a good flow control valve but I wanted cheap and found it on ebay but searching I cannot find the web site anymore. It was brand new but made in china. It works good though.
If and when I get pictures you will see what I have. 2" square pipe is a little pricey but if you go to a steel supplier it will be in 10 to 20 foot lengths, priced per foot but more if you don't want the whole bar and they cut to length. Ask for a DROP which is a smaller piece that someone else didn't want the entire length and they paid for the price hit. Usually you can get it that way much cheaper.
/ Can PT-425 handle Sabre Saw? #11
Yes, I have that saw. 3.3 GPM is about right for correct oscillation speed of the sickle. I run the tractor at about 1000 RPM to get that low flow. In order for the sickle to be able to cut anything more than a twig the motor driving it is going to have to supply some torque. 500PSI is probably the pressure across the motor while it is just oscillating the sickle but not cutting. The company claim is that the cutter is good for stuf up to 1". As the motor supplies the torque necessary to push the sickle thru, the pressure across the motor rises -- up to as high as the relief pressure of your system. There, if it hasnt cut, the motor stalls. If you have talked to someone at the company that told you the pressure required by the product is 500psi while cutting they just dont understand the product. Ask for a tech person.
larry
/ Can PT-425 handle Sabre Saw? #12
A couple things should be mentioned, here...
The original poster has a Power Trac with an air cooled engine meant to run at 3500 RPM (approximately) for proper cooling and lubrication. Running it at lower RPMs for extended periods of time to reduce the hydraulic pressure will also slow the cooling fan, reduce internal lubrication and could overheat the engine. Especially when using a cutter type attachment.
/ Can PT-425 handle Sabre Saw? #13
You want to reduce flow to the motor if delivery is above the 3.5gpm range. You want to keep full system pressure available. If you cant safely slow the engine to give appropriate ~3.5 flow you will need a flow divider to accomplish it.
larry
/ Can PT-425 handle Sabre Saw? #14
When the hyd pump is running, it is providing potential pressure. The resistance of the hyd motor will develop the pressure, and I am guessing here, that at about 500 psi, the sickle bar mower is cutting avg soft stuff. If it should get into some hard wood, the pressure will increase, and the pressure will build to the pumps potential. Either the motor will take it or fail.
You need to relieve the pressure at whatever the manufacture suggested, especially for warranty.
An external relief valve should work.
I would call the manufacture and double check.
This is a divider valve, with relief, but it doesn't say the lowest relief pressure.
https://www.surpluscenter.com/item.asp?item=9-4158-4&catname=hydraulic
/ Can PT-425 handle Sabre Saw? #15
Here is the manual for the saw.
http://www.cutthat.com/pdf/SabreManual.pdf
It says that the saw will run normally at 500 psi. It doesn't say anything about regulating the pressure. What is the manufacturer on the hyd motor?
This is the relief valve, which you could probably modify the spring to relieve at a lower pressure.
https://www.surpluscenter.com/Instruct/I9-4158-4.pdf
Relief valve 500 to 1500 psi
From the Q&A page:
"We use the following:
Charlyn (H) Series - #101-1001
Or Dan Foss - #151-2121
Or Ross - #MK021310AAAB
The motors are interchangeable mount and capacity but if parts are required you should specify the make and the model to obtain the correct parts from any hydraulic repair depot."
/ Can PT-425 handle Sabre Saw? #17
Ready for the irony? If those part numbers all sound familiar, try should.
Those are the same model numbers of hydraulic motors that PT uses on their brush hogs (and maybe their mower deck).
So the hydraulic motors should be able to handle PTO outlet pressure. You don't need a high quality pressure regulator valve plus reliefto keep from blowing it up.
But you do need a diverter valve (or cheap bypass pressure regulator) to keep the blades moving at the right speed. Full flow might be a little too fast... By a factor of 2-3 times.
/ Can PT-425 handle Sabre Saw? #18
This is a 2.8 cu in motor, and if 4 GPM are used, the shaft speed will be 330 rpm. Torque, using 2500 psi, will be 1,115 in lbs.
If you put 8 GPM to this motor, it will run at 660 rpm.
This motor is capable of 2500 psi.
The components in the saw may not not be able to take all the torque the motor can produce, and 500 psi may be a safe limit.
If you must limit this motor to 500 psi, then the torque will only be 223 in lbs, not very much.
That is about as much as a person can do with an anvil pruner.
/ Can PT-425 handle Sabre Saw? #19
larry
larry
larry
Pertinent points consolidated. :thumbsup: In actual practice the product shows that 2500psi stall causes no damage. This will seldom happen on green wood, even a little above an inch. Seasoned trimmings can be a bit harder to cut.
larry
Thanks to all who responded. Your responses was a great help in understanding the requirements.
I am going with using the PTO (8 GPMs) as the main drive circuit. Tim suggested that:
"So the hydraulic motors should be able to handle PTO outlet pressure. You don't need a high quality pressure regulator valve plus relief to keep from blowing it up. But you do need a diverter valve (or cheap bypass pressure regulator) to keep the blades moving at the right speed."
The nomenclature used here in the thread is somewhat different than product titles used in the catalogs. I am not confident of selecting the right "valve". I think that the thread concludes that all I need is a "flow regulator" that can reduce the PTO 8 GPM to 3.3 GPM. A separate or included "pressure regulator" is not needed.
Can anyone suggest a product that satisfies the requirement?
2015 Sealine F380 Flybridge Motor Yacht Boat (A59231)
2015 Sealine F380...
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
AGROTK YC-32G Horizontal Band Saw (A60463)
AGROTK YC-32G...
New Quick Attach Hay Spear (A61166)
New Quick Attach...
2011 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR3BJ325816 (A61165)
2011 International...
HYSTER S60FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S60FT...
