447 & 448 buckets
/ 447 & 448 buckets #1
GreatWhitehunter
Eastern CT
JD 110 TLB
Does anyone know if buckets from a 447 would fit on a 448? I wish deere gave a spec sheet on dimensions of the pin spacing. Additionally if anyone with a 447 could post the measurements of the pin spacing I could check it against my 448. Thanks
Matt
/ 447 & 448 buckets #2
Matt
Of course you could just go to Deere's parts site and compare the specs of the pins and you would see that the 447 pin is 1" x 7.375 and the 448 pin is 1.25" x 10.25". This doesn't tell you ear spacing but does tell you that a 447 bucket will not fit a 448 without going to a smaller pin and using bushings on the imp side.
/ 447 & 448 buckets
I did look on deere's part site and say different pin part numbers. Where did you see a size? I think the ear spacing is more narrow than I need. I'm sure I could make it work.
Matt
/ 447 & 448 buckets #4
I don't think they will work.. The 447 dipperstick is smaller than the 448. So the mounting ears will be too close together.
/ 447 & 448 buckets
I think your correct tom, I found a 36" bucket local to me for a 447. I've wanted a ditch bucket for my 448 for awhile so I was thinking of buying and modifying it to work. But with the cost of the bucket and price to mod it I'll be within $100 of buying a brand new one for my 448.
Matt
/ 447 & 448 buckets #6
Matt
Add the pins to your cart, it will show the sizes there.;)
2014 Ford F-550 Altec AT40M 40ft Material Handling Bucket Truck (A61568)
2014 Ford F-550...
2002 48ft. T/A Flatbed Trailer (A61573)
2002 48ft. T/A...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
Ford F-450 (A63689)
Ford F-450 (A63689)
2019 CAT 259D (A60462)
1057 (A63291)
1057 (A63291)
