447 & 448 buckets
/ 447 & 448 buckets #1
GreatWhitehunter
Eastern CT
JD 110 TLB
Does anyone know if buckets from a 447 would fit on a 448? I wish deere gave a spec sheet on dimensions of the pin spacing. Additionally if anyone with a 447 could post the measurements of the pin spacing I could check it against my 448. Thanks
Matt
/ 447 & 448 buckets #2
Matt
Of course you could just go to Deere's parts site and compare the specs of the pins and you would see that the 447 pin is 1" x 7.375 and the 448 pin is 1.25" x 10.25". This doesn't tell you ear spacing but does tell you that a 447 bucket will not fit a 448 without going to a smaller pin and using bushings on the imp side.
/ 447 & 448 buckets
I did look on deere's part site and say different pin part numbers. Where did you see a size? I think the ear spacing is more narrow than I need. I'm sure I could make it work.
Matt
/ 447 & 448 buckets #4
I don't think they will work.. The 447 dipperstick is smaller than the 448. So the mounting ears will be too close together.
/ 447 & 448 buckets
I think your correct tom, I found a 36" bucket local to me for a 447. I've wanted a ditch bucket for my 448 for awhile so I was thinking of buying and modifying it to work. But with the cost of the bucket and price to mod it I'll be within $100 of buying a brand new one for my 448.
Matt
/ 447 & 448 buckets #6
Matt
Add the pins to your cart, it will show the sizes there.;)
F-250 SuperDuty (A63689)
F-250 SuperDuty...
2013 Dodge Charger Sedan (A61574)
2013 Dodge Charger...
2014 Ford F-150 Pickup Truck (A61573)
2014 Ford F-150...
2020 CATERPILLAR 140 AWD MOTORGRADER (A63276)
2020 CATERPILLAR...
Zero Turn Mower (A59231)
Zero Turn Mower...
2007 Freightliner FLD120 (A62679)
2007 Freightliner...
