tn70 won't lift
   / tn70 won't lift #1
georaider
new holland tn70
I WAS WORKING CUTTING FIELDS UNHOOKED ONE CUTTER BACKED UP TO OTHER HOOKED UP BUT WILL NOT LIFT.UNHOOKED STILL NO LIFT CHANGED HY FILTER STILL NO LIFT HELP!!
   / tn70 won't lift #2
Do you have the automatic lift system on your tractor? I can't trmrmber exactly how it works but you either have to push the button to activate it or latch it closed to make the 3 pt controls work manually. I don't have the manual for my TD95D handy but I had a similar problem when I first got the tractor and I could not command the lift with the normal lift levers.
   / tn70 won't lift #3
draft control?
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
2002 WACKER RD25 ROLLER (A51222)
2002 WACKER RD25...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A50459)
2007 FORD F-750XL...
2016 Laymor SM300 Towable Ride-On Rotating Sweeper (A50322)
2016 Laymor SM300...
2001 STERLING WATER TRUCK (A51243)
2001 STERLING...
1994 Toyota 6000lbs 2 Stage Forklift (A52128)
1994 Toyota...
